Thread: power window noise
Results 1 to 3 of 3
  1. #1 power window noise
    SE Level Member Ryansgtp's Avatar
    Jul 2010
    Medina NY
    Dunno if this is the right section but I got a question bout my windows. When I roll them up to about and inch and up from the top the window or something from inside the door starts clicking like crazy. Should I be worried about my window stops working?
    Just starting out on my 2001GTP.
    Intake, tints, audio, interior. More to come in the future
  2. #2 Re: power window noise
    Apr 2009
    Maine
    If it's a steady clicking noise then it's probably a failing regulator/motor.
    But if it's more of a snapping/cracking that's less frequent, it probably means there's a loose or broken bolt/rivet somewhere on the inside bracket. This usually only happens to coupes because of the weight of the larger windows.
    My passenger window has been snapping for over a year and I'm too lazy to fix it. It snaps a couple times when I first put it up, then continues to do it for 4-5 miles when I hit bumps. But it still works fine.
  3. #3 Re: power window noise
    Hurst, TX (DFW)
    x2 on the failing regulator/motor. I have had problems with my front and rear windows and found replacing the regulator/motor fixed it.
  1. Power window issues
    By dbinnc in forum Audio, Security & Visual Electronics
    Last Post: 08-29-2009, 10:04 AM
  2. Power window stumper
    By pbrumfield2007 in forum Introductions/Noob Questions
    Last Post: 08-12-2009, 11:25 AM
  3. Auto power window
    By cliffster99 in forum General Tech Discussion
    Last Post: 05-12-2009, 10:17 AM
