Thread: How can I remove the stock radio from my 98 GTP?
Results 1 to 4 of 4
  1. #1 How can I remove the stock radio from my 98 GTP?
    Jul 2010
    se idaho
    There's a large plastic cover that covers all the way from the gauges to the center console. I guess I would need to remove this piece first, but I see no screws to remove.
    If anyone could help or even show me a thread where this has been discussed before (couldn't find anything in the search). Thanks in advance
  2. #2 Re: How can I remove the stock radio from my 98 GTP?
    Charles City, IA
    It pulls off. Some take the kick panel off to make it easier to pull off. The kick panel is the thing above the drivers knees.
    SMGPFC Two Nipple General
  3. #3 Re: How can I remove the stock radio from my 98 GTP?
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    Yea the whole thing just pulls off.. just be careful because the clips break easily.. Once you have it off you can unplug the fog light switch and get the piece out of the way
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  4. #4 Re: How can I remove the stock radio from my 98 GTP?
    Hurst, TX (DFW)
    Down by the pedals is a cover held on by two black trees. Pull them out and remove the cover. Then remove two screws holding the panel below the steering wheel. This will make the trim bezel easier to remove. Put the tilt all the way down on the steering wheel. Gently pull on the trim until all the clips release. If your car is equipped with fog lights you will need to undo the harness before you completely remove the trim bezel.
  1. how to remove stock stereo
    By izup69 in forum 04+ Specifics
    Last Post: 08-18-2010, 04:45 PM
  2. How do you remove the radio!?
    By jetscrazy44 in forum Visual/Body Modifications
    Last Post: 07-29-2010, 11:07 PM
  3. how do you remove the stock muffler
    By mezzoni in forum General Tech Discussion
    Last Post: 07-22-2010, 12:25 PM
  4. How to Remove Radio?
    By gpcruzin in forum Audio, Security & Visual Electronics
    Last Post: 06-07-2009, 11:42 PM
