Thread: Need advice setting my amp
Results 1 to 15 of 15
Colossus Need advice setting my amp 09-25-2010, 12:53 PM
I800C0LLECT Re: Need advice setting my amp 09-26-2010, 12:04 AM
Colossus Re: Need advice setting my amp 09-26-2010, 05:22 PM
I800C0LLECT Re: Need advice setting my amp 09-26-2010, 08:55 PM
matt5112 Re: Need advice setting my amp 09-26-2010, 08:59 PM
Colossus Re: Need advice setting my amp 09-26-2010, 10:13 PM
matt5112 Re: Need advice setting my amp 09-27-2010, 08:34 AM
chamilton89 Re: Need advice setting my amp 11-29-2010, 10:09 PM
matt5112 Re: Need advice setting my amp 11-29-2010, 10:17 PM
chamilton89 Re: Need advice setting my amp 11-29-2010, 10:49 PM
I800C0LLECT Re: Need advice setting my amp 12-02-2010, 01:52 AM
matt5112 Re: Need advice setting my amp 11-29-2010, 10:56 PM
boosted98 Re: Need advice setting my amp 12-01-2010, 11:40 PM
matt5112 Re: Need advice setting my amp 12-01-2010, 11:53 PM
matt5112 Re: Need advice setting my amp 12-02-2010, 01:54 AM
  1. #1 Re: Need advice setting my amp
    Can you clairify the bit about large cones not handling anything? Because that seems back-ass-wards.
    You can calculate at what frequency a speaker will begin beaming, 18's dont beam till around 200 which is still not that low.
    When you can hear audible distortion you're at 10% THD+N typically...
    which is about 10 times as much as you want.
    Loudness curves neutralize themselves as you turn it up... they take care of themselves.
  2. #2 Re: Need advice setting my amp
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    I would never push an 18 past 80 hertz. I am not worried about beaming in a speaker, just because I speaker can handle a frequency doesn't mean it should. anything above 100 hrtz gives terrible phase distortion as the loudspeaker is trying to produce a bass kick at 30 hrtz and a bass guitar at 80. a 5 and a quarter loudspeaker is capable of delivering down to like 30 hrtz but would you ever do that, hell no. There is a reason I have my 12inch subs crossover at 60 hrtz and my 8 inch woofers crossover at 120 hrtz, then my mids pick up above that. It gets muddy as the speaker cone gets larger and the frequency goes up, sure the speaker CAN but should it ever produce above 100 hertz, hell to the no.
  3. #3 Re: Need advice setting my amp
    Feb 2009
    Virginia
    Quote Originally Posted by chamilton89 View Post
    Are you trying to refer to 2nd and 3rd order harmonics? Typically, those issues are much more dependent on your ability to integrate the sub with mid-bass and mid-range. You should check out pro audio.
    11 is louder than 10!
  1. setting up new system
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2009, 11:27 PM
  2. Complaint With One Of This Forums Setting
    By Street Wolf in forum Forum Bugs/Suggestions
    Last Post: 12-22-2008, 01:29 PM
  3. any interest in setting up IRC channel?
    By fst in forum Forum Bugs/Suggestions
    Last Post: 12-13-2008, 02:56 PM
  4. Setting up account
    By PWNED in forum PCM Tuning
    Last Post: 08-23-2008, 06:29 AM
  5. Hood not setting right.
    By DanGTP in forum Visual/Body Modifications
    Last Post: 03-02-2008, 01:43 AM
