Thread: Aftermarket Amp Question
Results 1 to 13 of 13
  1. #1 Aftermarket Amp Question
    dayton
    i am looking at purchasing a 2002 GTP 40th Anniversary Edition (w/o Bose or SC) and am wondering where on the firewall is a good place to drill a hole to route either a 1/0 or 4 gauge amplifier wire? i know the battery is on the passenger side, but so far i cannot see any good places to drill or just slit and pass thru. i know i dont want to run it in the door jamb. ANY HELP WILL BE GREATLY APPRECIATED
  2. #2 Re: Aftermarket Amp Question
    swift current,sask.
    That will save you a lot of problems, just peel the carpet back on the passanger's side and you will be able to feed the wire through there.
  3. #3 Re: Aftermarket Amp Question
  4. #4 Re: Aftermarket Amp Question
    dayton
    Thanks for the help i will look for that once i get the car. Also, does anybody know if i can mount a set of 6 1/2" speakers to the door sheetmetal itself? i dont want to modify the stock mounts unless i have to and 5.25" speakers aren't really big enough...
  5. #5 Re: Aftermarket Amp Question
    swift current,sask.
    Yes, it is possible. There is quite a big opening there, you could just cut yourself out a mdf ring to go around it. That's what the holes in the panel look like...
    I just hacked apart my plastic pieces to make them fit. Lol
  6. #6 Re: Aftermarket Amp Question
    dayton
    will that opening fit (top mount depth-wise) some nice pioneer or rockford fosgate 6 1/2 inch components and what plastic pieces are there? also (sorry so many questions) is there any way of removing or disabling the HUD system and OnStar systems? those are nothing but wastes of metal and silicon in my opinion
  7. #7 Re: Aftermarket Amp Question
    swift current,sask.
    Quote Originally Posted by crash1340 View Post
    Yes, my alpine type-r's fit in there with lots of room to spare. There are basically adaptor plates made out of plastic that you mount the speaker in and mount to the sheet metal. Nothing a pair of side cutters won't fix. Lol you should just be able to unplug all of that and hae no problrms.
  8. #8 Re: Aftermarket Amp Question
    dayton
    okay, thank you for your help. if i need anything else, i will be sure to post something...
  9. #9 Re: Aftermarket Amp Question
    swift current,sask.
    No problem! that's what the forum is for.
  10. #10 Re: Aftermarket Amp Question
    Feb 2009
    Virginia
    whiney = good people!!
    11 is louder than 10!
  11. #11 Re: Aftermarket Amp Question
    SE Level Member Paul79UF's Avatar
    Florida
    I've got the power wires running down the passenger side of my '01. There is a rubber grommet on the firewall that you can pop out, make a hole, and run your power wire through.
    Keep the speaker wires on the other side of the car to prevent interference.
  12. #12 Re: Aftermarket Amp Question
    first off, thread is a tad aged.
    second, see pic above.
    third, speaker wires dont need to be separated, the RCA's do... but if they're properly shielded then it wont matter.
  13. #13 Re: Aftermarket Amp Question
    dayton
    just to clarify, does the dash front panel (front purple piece on my gtp) just pop off (relatively) easily? i dont want to break anything when i install my new receiver
    in a few days
  1. Aftermarket Rims Fit?
    By 04montecarloss in forum Tires & Wheels
    Last Post: 08-01-2010, 05:41 PM
  2. Aftermarket Radio Question
    By antbanks2286 in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2010, 02:25 PM
  3. 97 aftermarket hu factoy amp
    By pmurder in forum Audio, Security & Visual Electronics
    Last Post: 12-13-2009, 09:02 PM
  4. aftermarket HU
    By cincygoat in forum Audio, Security & Visual Electronics
    Last Post: 10-29-2009, 09:40 PM
  5. Aftermarket FPR's?
    By TDCRacing in forum General Tech Discussion
    Last Post: 09-04-2008, 11:54 AM
