Thread: Rear Blinker
Results 1 to 5 of 5
  1. #1 Re: Rear Blinker
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    YEah figured it out when I got home very simple. Damn light has moisture all over inside the housing... Need to fix that mad
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  2. #2 Re: Rear Blinker
    MA
    Quote Originally Posted by tayl5645 View Post
    Hmm, My 2002 I replaced the rear bulbs and THEN developed a leak?? My drivers side now FILLS with water when it rains. I thing the harness washer are old and leak and when I disturbed them that was it? Tried silicone grease but still leaks. So for now I drilled a small hole in the bottom of the housing to let the water drain.
  1. I Need help blinker problem..
    By 05silverbullit in forum General Tech Discussion
    Last Post: 12-23-2010, 03:21 PM
  2. Rear end Sag
    By Pontiac Warrior in forum Brakes/Suspension/Chassis
    Last Post: 05-18-2010, 07:42 PM
  3. Rear End Help
    By Juice-08 in forum Visual/Body Modifications
    Last Post: 06-03-2009, 07:13 PM
  4. rear o2
    Last Post: 04-21-2009, 02:54 PM
  5. Rear STB only...
    By a3gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-08-2009, 06:17 PM
