I'm pretty sure the headlight and a/c problem is the ignition switch (had same problem with my old 02 GT) it has something to do with the drl's being all wired through ignition switch. As far as the trunk problem no idea.
I've also heard/seen issues with blower control/headlights being part of the ign switch. Seems like they pulled 99% of the power for the car on a 50gauge wire in the ignition switch. lol
Trunk popping.. check the button in the glove box. If it's stuck or something that could happen.
Thank you for the replies! The ignition switch sounds like it will be the answer to the first problem. For the second one, I forgot to post this, but both the driver side and passenger side door locks work to unlock the vehicle, but neither work to lock the vehicle. They both went as soon as the car started popping the trunk.
