Thread: Electronic Gremlins
Results 1 to 7 of 7
  1. #1 Electronic Gremlins
    Edmonton
    Hello, new to the forums... I have a few things that are happening to my 2002 grand prix gt.
    The first thing has been happening for a long time now. The air conditioning only works on full blast, if it is on 1 2 3 or 4 it doesn't work... and the head lights go off if it is put to those non working levels...
    Second just happened recently. When I shift my car into park... the trunk pops...
    any ideas?
  2. #2 Re: Electronic Gremlins
    Willoughby, Ohio
    welcome to the forums, i can tell you that the A/C problem is your blower motor resistor, its probably fried and needs replaced. the headlights going off with that problem is something ive never heard of but will hopefully go away with the replacement of the resistor. as for the trunk popping when in park, not sure, never heard of that either hopefully someone will chime in who knows about that
  3. #3 Re: Electronic Gremlins
    SE Level Member spiderjohn's Avatar
    Jun 2010
    W Warwick R.I
    I'm pretty sure the headlight and a/c problem is the ignition switch (had same problem with my old 02 GT) it has something to do with the drl's being all wired through ignition switch. As far as the trunk problem no idea.
    2005 Grand Prix GT
    89 Chevrolet c1500
  4. #4 Re: Electronic Gremlins
    I've also heard/seen issues with blower control/headlights being part of the ign switch. Seems like they pulled 99% of the power for the car on a 50gauge wire in the ignition switch. lol
    Trunk popping.. check the button in the glove box. If it's stuck or something that could happen.
  5. #5 Re: Electronic Gremlins
    Akron Ohio
    X2^^^
  6. #6 Re: Electronic Gremlins
    Edmonton
    Thank you for the replies! The ignition switch sounds like it will be the answer to the first problem. For the second one, I forgot to post this, but both the driver side and passenger side door locks work to unlock the vehicle, but neither work to lock the vehicle. They both went as soon as the car started popping the trunk.
  7. #7 Re: Electronic Gremlins
    Pennsylvania
    Quote Originally Posted by spiderjohn View Post
    Parking lights come on when shifting into park... maybe trunk is wired through those or something?
  1. Electronic Connections
    By Ibwrong in forum General Tech Discussion
    Last Post: 12-17-2009, 06:41 PM
  2. electronic dist
    By HARLEYBAYO in forum Introductions/Noob Questions
    Last Post: 11-18-2009, 12:15 PM
  3. Electronic boost controller
    By TDCRacing in forum Turbo
    Last Post: 10-28-2009, 11:26 PM
  4. Electronic Cutout!?!?!?
    By nicksilvergt99 in forum General Tech Discussion
    Last Post: 08-06-2009, 08:12 PM
  5. ABDS/TCS gremlins
    By marchi1 in forum Brakes/Suspension/Chassis
    Last Post: 01-07-2008, 07:00 AM
