Thread: HUD working intermittently ('97 GTP)
Results 1 to 2 of 2
  1. #1 HUD working intermittently ('97 GTP)
    SE Level Member Powertrike's Avatar
    Jul 2010
    MN, US
    Sometimes it works, sometimes it doesn't. The mirror appears to be working correctly at all times and when the H.U.D works, the dimmer control seems to work fine and all is bright. I've read about the seemingly common fading in and out issue but this appears to be different. Ideas on what I can check? I haven't had a chance to get a wiring diagram and check basic power/grounds yet but the mirror adjustment does work fine. Ideas? Fairly easy to remove and check solder connections?
  2. #2 Re: HUD working intermittently ('97 GTP)
    Outer Space
    02 GTP 13.6 @ 100mph - SOLD
  1. HUD works intermittently
    By Phyrstorm in forum Audio, Security & Visual Electronics
    Last Post: 01-30-2012, 09:08 PM
  2. HUD and GPS going out intermittently?
    By Jas0n in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2010, 08:22 PM
  3. Key intermittently won't come out of ignition
    By atclarkson in forum General Tech Discussion
    Last Post: 06-09-2010, 09:47 AM
  4. Low Oil Level Warning on Intermittently
    By Panzer4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2009, 10:09 AM
  5. Rear windows intermittently work
    By 98GT3800 in forum General Tech Discussion
    Last Post: 11-20-2008, 07:33 PM
