Thread: Need a little help with reverse wire
Results 1 to 9 of 9
  1. #1 Need a little help with reverse wire
    SE Level Member christopher8911's Avatar
    North Carolina
    Almost finished setting up my stereo system. All I have left is to find a place where I can tap my reverse switch wire to the car. This is the wire at my head unit that automatically switches the video display to the reverse camera when I put the car in reverse. I know I can tap the green wire in the trunk, but im looking for a wire to tap in the dash or console area so I dont have to run a wire all the way back to the trunk. Any help would be great, thanks guys.
  2. #2 Re: Need a little help with reverse wire
    follow the wiring harness on the passengers side of the car.
  3. #3 Re: Need a little help with reverse wire
    swift current,sask.
    In that harness there will be a light green wire, that is the one you want to tap into for power.
  4. #4 Re: Need a little help with reverse wire
    I could look it up if you had mentioned what year and model you drive.
  5. #5 Re: Need a little help with reverse wire
    North Carolina
    Its a 1998 GP GT. Sorry
  6. #6 Re: Need a little help with reverse wire
    North Carolina
    Bump
  7. #7 Re: Need a little help with reverse wire
    swift current,sask.
    Quote Originally Posted by whiney View Post
    ok, please re-read what I said... That applies for all 97-03 grand prix's...
  8. #8 Re: Need a little help with reverse wire
    North Carolina
    I get what your saying about the green wire but I assumed that the reverse signal wire ran behind the dash at some location. I wanted to tap one of the wires under the dash so I wouldn't have to have wires under the carpet. Looks like I will have to tap the green wire in the door seal since I can't find a wire schematic of the reverse system. Thanks for the info given though
  9. #9 Re: Need a little help with reverse wire
    North Carolina
    Finally got to this yesterday. Tapped the wire in the harness under the glovebox. Love the reverse camera since I can't see anything at dark with my windows tinted and taillights smoked. Thanks for the help guys
  1. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  2. Popping In Reverse
    By Chmanzi in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-20-2010, 11:00 PM
  3. clunk going into reverse????
    By vader99 in forum General Tech Discussion
    Last Post: 01-20-2010, 07:44 PM
  4. reverse
    By gotboost3 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2009, 11:23 AM
