Thread: got subs...but what amp?
Results 1 to 13 of 13
  1. #1 got subs...but what amp?
    Arizona
    so i just got 2 rockford fosgate punch p1 10s and a alpine mrp350 amp and im psotive they are underpowered by that amp. im looking for a good upgrade for my amp, what should i get?
    '00 GT- nothing special
  2. #2 Re: got subs...but what amp?
    Arizona
    so for now im just going with the amo and one sub till i upgrade and get 2, but for wiring.... ground wire...where did u guys hook urs?
    how did u guys fasten ur stuff down
  3. #3 Re: got subs...but what amp?
    Jul 2008
    sumter,south carolina
    i tapped into the seal belt bolts for ground... and i always recommend memphis for amps.
    02 GTP with mods 05 GP for DD
  4. #4 Re: got subs...but what amp?
    Grand Blanc, MI
    Do you have your subs wired at a 2ohm load and your amp bridged? Your subs are only 150w RMS each and your amp puts out 350w RMS at 2ohms. Do the math and you'll see you won't be under powering them if you hook them up correctly. My guess is you have them wired as an 8 ohm load and they are only getting about half their RMS wattage.
  5. #5 Re: got subs...but what amp?
    Arizona
    i only have one hooked up as of now is that ok to do?
  6. #6 Re: got subs...but what amp?
    Jul 2008
    2 channel amp?
  7. #7 Re: got subs...but what amp?
    Arizona
    it has 2 outputs...
  8. #8 Re: got subs...but what amp?
    Grand Blanc, MI
    yes that is fine to do. that amp should be perfect for either one sub at 4ohm which is the only wiring option (200w going to a 150w sub) or 2 subs wired at 2ohms (350w going to 300w worth of subs). Forget what I said about "bridging" your amp basicly automatically does it.
    In the diagram above, your amp would be on the left hand side.
    Basicly what I'm getting at is that is a very good amp for those subs. Don't waste your money buying a new amp because you won't be any happier. Its either your enclosure or your subs that you are not satisfied with.
  9. #9 Re: got subs...but what amp?
    Arizona
    so should i go by that diagram?
  10. #10 Re: got subs...but what amp?
    Grand Blanc, MI
    Quote Originally Posted by coreygnar View Post
    Yes, at least try it. I bet you'll be happy. Alpine is a quality amp, Fosgate P1's are...meh. But the enclosure is what makes the sub sound good. Try wiring both like the 2 ohm diagram. If your still not satisfied (but I think you will be) I bet your enclosure is not built to the subs specs and is to blame.
  11. #11 Re: got subs...but what amp?
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    theres ONLY 2 ways of hooking them up...
    parallel
    and series
    as for the ground i have mine on the pass side strut mount works good make sure you take the paint off your grounds tho
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  12. #12 Re: got subs...but what amp?
    Arizona
    ok how do u guts fasten down ur stuff?
  13. #13 Re: got subs...but what amp?
    its AWDsome JarenSTi's Avatar
    Hawaii
    bunjee cord around the box
    2002 WS.6- exhaust, 42k miles
    2005 Subaru WRX
    2002 GT - sold
  1. Need new subs
    By robahr24 in forum Audio, Security & Visual Electronics
    Last Post: 01-04-2010, 10:52 PM
  2. My new HID's and subs
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 06-27-2009, 09:55 PM
  3. jvc subs
    By zach_gt in forum Audio, Security & Visual Electronics
    Last Post: 10-17-2008, 11:38 PM
