Ok searched around and couldnt find it. Havent even looked on the car as it happened on the way to work :-P. How do I get in to change the rear turn signal? its the Drivers side even though it shouldnt make a difference. I should mention its an 05
YEah figured it out when I got home very simple. Damn light has moisture all over inside the housing... Need to fix that mad
Hmm, My 2002 I replaced the rear bulbs and THEN developed a leak?? My drivers side now FILLS with water when it rains. I thing the harness washer are old and leak and when I disturbed them that was it? Tried silicone grease but still leaks. So for now I drilled a small hole in the bottom of the housing to let the water drain.
