Thread: FACTORY MONSOON WIRING DIAGRAM for Audio system Install using LOC
Results 1 to 14 of 14
  1. #1 Re: FACTORY MONSOON WIRING DIAGRAM for Audio system Install using LOC
    SE Level Member ivorywhiteRIC's Avatar
    Feb 2010
    cleveland, ohio
    which wires did you use on the blue and green?? all four speaker wires from the LOC???
    from the LOC they have 3 pairs of wires (right and left), and a single remote lead... confused on which ones you used and if only used a single pair where did you connect the others??
  2. #2 Re: FACTORY MONSOON WIRING DIAGRAM for Audio system Install using LOC
    SE Level Member Chillery's Avatar
    Illinois
    I hooked the right side to the blue and green and the same on the left. my loc just has a right, left, and optional ground. I did not need the ground so just hooked them into both speakers.. hope that helped.
  3. #3 Re: FACTORY MONSOON WIRING DIAGRAM for Audio system Install using LOC
    indiana
    First post question. I am in the process of adding a JL 13w6v2 and JL 500/1 o my 05 factory monsoon, I know I need a LOC but there are contrasting remarks on here, I have already replaced all my stock speakers with Alpine type S and when doing the rear 6x9's i notice of course the dual wires per speaker, one being a low pass "sub" and the other being a high pass i assume...I only connected the low pass to add more bass while waiting on sub box. Should I swap those out and connect the low pass to the LOC and then connect the high pass back to the 6x9's to had mid and treble? sorry if i have confused.
    Also I am running the 13w6v2 @ 2 ohms i assume thats ok? its been 7 years since ive had a system of anytype, so its like starting over
    and it says i can run the remote to my 500/1 off the factory amp buy using the pink or purple wire??? i assume i can splice into that on one of the 3 harnesses going into the monsoon amp?
  1. Need PCM wiring diagram or perhaps pin for MAF
    By aimhigh86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2010, 01:00 PM
  2. Monsoon wiring diagram?
    By GiAnT4LYFE in forum Audio, Security & Visual Electronics
    Last Post: 04-30-2009, 03:34 PM
  3. Monsoon Amp Remote Wire and Speaker wiring diagram
    By Thatonepunkrawk in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2009, 07:58 PM
  4. Wiring Diagram, Ignition/security system
    By boogsey in forum General Tech Discussion
    Last Post: 12-25-2008, 11:32 PM
  5. wiring diagram for 05 non monsoon
    By 05grndprix in forum Audio, Security & Visual Electronics
    Last Post: 10-07-2008, 02:56 AM
