Thread: Stock Stereo replacement
Results 1 to 8 of 8
  1. #1 Re: Stock Stereo replacement
    GTP Level Member SuperSport's Avatar
    Michigan
    So the bulbs burn out in your radio display and you want a new radio? Thats like having your tail light burning out and scrapping your whole car...
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  2. #2 Re: Stock Stereo replacement
    SE Level Member Eking's Avatar
    Jun 2010
    Canada
    You should be able to use the stock XM antenna. You would have to mount your new XM module where the stock one is and you may have to remove the plastic cover on the stock antenna end to make it fit. I have done this on many newer GM vehicles and have not any problems. One last note is you will want a XM that's a hide-a-way piece not one you mount on the windshield or dash. Evan
    01 GTP Special Edition!
  3. #3 Re: Stock Stereo replacement
    Jun 2010
    Missouri
    That is an interesting analogy there, but why don't you show me how to put a lightbulb in an lcd radio display.
  4. #4 Re: Stock Stereo replacement
    Michigan
    Ask and you shall receive.
    This link shows the older style GP radios, and yours is the same concept, except I believe your style has 3 bulbs.
    You are correct that it is LCD display, but the backlight shines thru it so you can see the display.
    Radio Lamp Repair
    Not sure how to dismantle the newer radios, but Im guessing its not too difficult.
    Of course you dont have to listen to me, Im just being a cheap ass, but thats the link if you decide to do it.
    Hope this helps.
  1. Stock Stereo
    By corbancantread in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2010, 06:46 PM
  2. If I put a new stereo in would I still be able to use the stock tweeters>?
    By salannelson in forum Audio, Security & Visual Electronics
    Last Post: 09-24-2009, 09:21 PM
  3. stock stereo switch?
    By pski920 in forum Audio, Security & Visual Electronics
    Last Post: 12-17-2008, 11:20 AM
  4. Stock stereo backlight inop? Which speakers to replace stock?
    By Z28 in forum Audio, Security & Visual Electronics
    Last Post: 12-04-2008, 11:47 PM
  5. stock stereo
    By 59chevy in forum Audio, Security & Visual Electronics
    Last Post: 02-09-2008, 12:01 PM
