You should be able to use the stock XM antenna. You would have to mount your new XM module where the stock one is and you may have to remove the plastic cover on the stock antenna end to make it fit. I have done this on many newer GM vehicles and have not any problems. One last note is you will want a XM that's a hide-a-way piece not one you mount on the windshield or dash. Evan
