alright that scan would most likely save my butt here. the only thing is I counted 19 wires. What do I do if some do connect to the Aftermarkets harness OR there are two of the same color (cause there are like 3 wires each has a 2nd one the exact same color)
Here is a scan of the harness you get from Crutchfield. It might help with some identification. These wires on the harness get wired to the aftermarket radio harness. Mine is a 2000 GTP, so I assume this should be the same harness you would get if you ordered one.
