Thread: 6x9 doesn't fit in rear opening! help!
Results 1 to 8 of 8
  1. #1 6x9 doesn't fit in rear opening! help!
    SE Level Member jstevanus's Avatar
    Feb 2010
    Michigan
    I tried installing a pair of Infinity Reference 6x9's in the rear deck and they won't fit! The metal "baskets" on the back of the speaker won't fit through the opening, and now the speakers stick up about 1/4". What the hell am I supposed to do about this?
  2. #2 Re: 6x9 doesn't fit in rear opening! help!
    how is that possible?
    What is it hitting?
    TAKE SOME PICTURES PLZ.
  3. #3 Re: 6x9 doesn't fit in rear opening! help!
    GTP Level Member SuperSport's Avatar
    Michigan
    Hmm, my 6x9's are Infinity's and they fit fine. Yes take some pics, something isnt right.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  4. #4 Re: 6x9 doesn't fit in rear opening! help!
    Donating Users Warbeaver's Avatar
    St. Louis
    what he's referring to is the plastic parts that go around the speaker. they go from the top of the speaker, down towards the base. I had the same problem on a grand am gt with some 6x9 kenwoods. I couldn't figure it out, so took it to a shop. they just took some pliers, and bend the metal downward all the way around until the hole was big enough. You could also take a dremel and hollow out the opening. These same 6x9 kenwoods, fit perfect in my grand prix with no modification though......
  5. #5 Re: 6x9 doesn't fit in rear opening! help!
    Feb 2010
    Michigan
    I have an 06 GXP.. maybe the openings are different? The stocks are definitely 6x9 openings. It's just that the hole that the bottom of the speaker sticks through down into the trunk isn't big enough for the back of the Infinity speaker. I will have to cut away at the metal opening to make it fit! I will take some pics shortly.
  6. #6 Re: 6x9 doesn't fit in rear opening! help!
    Arizona
    i have the same problem but with 4 inch speakers in the rear
    HELP US!!!
    '00 GT- nothing special
  7. #7 Re: 6x9 doesn't fit in rear opening! help!
    Wadsworth, IL
    thats weird on my 05 best buy never had a problem with installing my infinity kappa 6x9s. then again i prly shouldnt have let them do it to begin with cuz my $300 Pioneer touch screen head unit only works when it wants too. Prbly cuz those idiots hooked it up to my parking lamps instead of my turn signal sooo yea they suck... sry im ranting here lol
    05 GTP w/ K&N Cold Air Intake, Dynomax Mufflers, Resonator Delete, Speed Daddy Headers, ZZP 180* TSTAT, 3800Performance 3.4" MPS, ZZP Ignition Wires & a DHP Tune
  8. #8 Re: 6x9 doesn't fit in rear opening! help!
    It shouldnt be hooked up to either : \
  1. DIC doesn't work at all.
    By hubert hefner in forum General Tech Discussion
    Last Post: 05-29-2010, 10:32 PM
  2. Rear View Mirror doesn't display temp and/or compass
    By Silent Drifter in forum General Tech Discussion
    Last Post: 04-23-2010, 09:11 PM
  3. Opening a door
    By speedracer88 in forum General Tech Discussion
    Last Post: 03-19-2009, 03:28 PM
  4. is my thermostat not opening?
    By nemesis in forum General Tech Discussion
    Last Post: 10-25-2008, 07:16 PM
  5. Cloverfield opening tomorow.
    By Reptile in forum Off Topic Discussion
    Last Post: 01-21-2008, 08:17 AM
