Thread: Does the Stock deck have RCA outputs
Results 1 to 13 of 13
  1. #1 Does the Stock deck have RCA outputs
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    2001 GTP Does the Stock deck have RCA Outputs
    No reason taking the deck out to install the amp if it does not have it
  2. #2 Re: Does the Stock deck have RCA outputs
    GrandPrix Junkie
    Saraland Alabama
    I have never seen a stock deck with outputs, it's more cost for the manufacturer to add something they don't want you to do anyway. Get a good line out converter and you'll be fine
  3. #3 Re: Does the Stock deck have RCA outputs
    Naugatuck CT
    Quote Originally Posted by archemedes View Post
    Yea that is what I figured but thought I would ask I went and bought a Amp kit today and I am going to start the install tommorow is it easy to get the Dash apart to get to the Deck
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  4. #4 Re: Does the Stock deck have RCA outputs
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    Its fairly easy, I posted up somewhere on here the tech sheets showing how to take apart everything. I will see if I can find that for you.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  5. #5 Re: Does the Stock deck have RCA outputs
    Naugatuck CT
    Quote Originally Posted by s1795so2 View Post
    I was tring to search but I could not find
  6. #6 Re: Does the Stock deck have RCA outputs
    Naugatuck CT
    I need to know if someone could help me how to hook up the line converter to the back of the stock deck.
    Also I was reding on the Contols for the steering wheel I am going to order one of those too
  7. #7 Re: Does the Stock deck have RCA outputs
    alhambra, Il
    Quote Originally Posted by jacobmh27 View Post
    There should be at least 2, sometimes 4 speaker leads coming off the LOC, hook these up to the rear speaker wires or front but rear is easier. Then there should be an accessory wire coming off the LOC hook this up to an accessory wire in the car. Then there should be a ground wire coming off The LOC hook this up to ground.
    Depending on which LOC you get, you sometimes get a remote turn on lead output of it so that is one less thing you have to worry about.
    -Steven-
    Steven Oliver
  8. #8 Re: Does the Stock deck have RCA outputs
    Naugatuck CT
    -Steven-
    I get ths part but what I am looking for is the Pin out of the Trunk Amplifier input from the Deck
    I am talking abot the stock amp that is mounted in the trunk I was planning on taking the input leads to the amp out and branching off to the LOC. I think that would be the best way right?
    The Problem is I do not know what input wires to come off of to get the correct connection. I am going to get a head unit in a few months and then I will be running of of that but for now I wanted to connect my box.
  9. #9 Re: Does the Stock deck have RCA outputs
    GT Level Member BackInBlack's Avatar
    Vermont
    If you are clever, you might be able to tap off the audio signals between the pre-amplifier and main amplifier on the radio's circuit... Find the main amplifier in the radio, probably the device with the biggest heatsink. Get the numbers off it and look up the datasheets on the internet. You might be able to easily work from there.
    The GPs are long gone...
  10. #10 Re: Does the Stock deck have RCA outputs
    GTX Level Member webracin's Avatar
    Arkansas
    I dont remember which ones I tapped into on my head unit (stock Bose), I know it was the rear speakers, and I tapped in the line out convertor at the head unit so that if I ever did replace the head unit, my RCA cables were already ran to the front of the car. Mine has been working for over 5 years with no problems. I will be taking out the head unit next week to replace the display bulb, so I can tell you what color wires and where its connected then if need be. Mine is also an 01 GTP so there should be no difference.
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  11. #11 Re: Does the Stock deck have RCA outputs
    SE Level Member GTP00Matt's Avatar
    May 2008
    Delavan, MN
    Not trying to hijack, but i'm in the same boat. Did you ever get this working?
    2000 GTP coupe, totally stock
    1995 Chevy K2500 6.5 TD 4" straight pipe 285 BFG's on 16x8 American Racing Nitro's
  12. #12 Re: Does the Stock deck have RCA outputs
    May 2008
    Delavan, MN
    bump. Like to get this working soon guys, help would be appreciated
  13. #13 Re: Does the Stock deck have RCA outputs
    SE Level Member gpaddictiongtp9798's Avatar
    Jun 2010
    elmwood park, il
    did you ever hook it up
  1. Stock Sparkplug's
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2008, 01:58 AM
  2. Need more input for stock 3.8 NA
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-01-2008, 07:19 PM
