Thread: Does the Stock deck have RCA outputs
Results 1 to 13 of 13
  1. #1 Re: Does the Stock deck have RCA outputs
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    Its fairly easy, I posted up somewhere on here the tech sheets showing how to take apart everything. I will see if I can find that for you.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  2. #2 Re: Does the Stock deck have RCA outputs
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    Quote Originally Posted by s1795so2 View Post
    I was tring to search but I could not find
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  3. #3 Re: Does the Stock deck have RCA outputs
    Naugatuck CT
    I need to know if someone could help me how to hook up the line converter to the back of the stock deck.
    Also I was reding on the Contols for the steering wheel I am going to order one of those too
  4. #4 Re: Does the Stock deck have RCA outputs
    alhambra, Il
    Quote Originally Posted by jacobmh27 View Post
    There should be at least 2, sometimes 4 speaker leads coming off the LOC, hook these up to the rear speaker wires or front but rear is easier. Then there should be an accessory wire coming off the LOC hook this up to an accessory wire in the car. Then there should be a ground wire coming off The LOC hook this up to ground.
    Depending on which LOC you get, you sometimes get a remote turn on lead output of it so that is one less thing you have to worry about.
    -Steven-
    Steven Oliver
  5. #5 Re: Does the Stock deck have RCA outputs
    Naugatuck CT
    -Steven-
    I get ths part but what I am looking for is the Pin out of the Trunk Amplifier input from the Deck
    I am talking abot the stock amp that is mounted in the trunk I was planning on taking the input leads to the amp out and branching off to the LOC. I think that would be the best way right?
    The Problem is I do not know what input wires to come off of to get the correct connection. I am going to get a head unit in a few months and then I will be running of of that but for now I wanted to connect my box.
  1. Stock Sparkplug's
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2008, 01:58 AM
  2. Need more input for stock 3.8 NA
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-01-2008, 07:19 PM
