Thread: amp problem
Results 1 to 4 of 4
grand2000prixgtp amp problem 04-18-2010, 09:16 PM
matt5112 Re: amp problem 04-19-2010, 10:31 AM
ZR1Vette09 Re: amp problem 04-19-2010, 06:39 PM
chamilton89 Re: amp problem 04-19-2010, 07:38 PM
  1. #1 amp problem
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    ok so in my boat i have 4 subs and they have been working good for the few years that i have owned the boat and last year one day they just stopped working the amp was getting power just not putting anything to the subs and i couldn't find it out. so i decided to hook up the kicker amp i had in my car to there and it sparked and the protection light comes on and it don't work and i don't know why. any ideas as why it would just stop working and blow a amp when i hook it up?
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  2. #2 Re: amp problem
    incorrect wiring? A short?
    You did disconnect the positive or negative from the battery before you hooked up the amp right?
  3. #3 Re: amp problem
    MO
    go through with a voltmeter and test all your + and - connections. Triple check your ground wire. Mine came loose so occasionally it would trip the protection.
    <brandonl2000> LMAO D!!
  4. #4 Re: amp problem
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Yeah Check and make sure your getting the correct voltage from your positive power (12-14.4v) that would turn on your protect light, also check your fuses on your amps make sure you didn't blow anything.
  1. a/c problem
    By mtz956 in forum How To Write-Ups/Tech Tips
    Last Post: 10-25-2009, 10:05 PM
  2. Yet another A/C problem
    By TexasFury in forum General Tech Discussion
    Last Post: 09-23-2009, 12:32 PM
  3. Might have a problem.
    By Pontiacman in forum General Tech Discussion
    Last Post: 12-26-2008, 08:57 PM
  4. DIC problem
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 04:41 PM
  5. What is the problem?
    By spidamanSS in forum General Tech Discussion
    Last Post: 05-07-2008, 12:56 AM
