Thread: Thoughts on cheap subs?
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 Thoughts on cheap subs?
    MO
    Decided i miss my old bass, so i wanna do something cheap. I don't need heart pounding bass, just enough to enjoy my rock and rap a little more. I just want a little bit of help choosing between a few of these.
    Rockford Fosgate P2D415 - 15" Subwoofers - Sonic Electronix
    15" Dual 4 ohm Punch Stage 2 Subwoofer
    Power Handling:
    • Peak: 500 watts
    • RMS: 250 watts
    Parabolic Triangular Geometry cone support system for reduced piston flex
    30oz. double-stacked magnet assembly increases excursion capability
    Compliant linear spider eliminates need for break-in period
    2" anodized aluminum voice coil former stays up to 100° cooler
    Reversible concealing ring hides mounting screws
    Large roll surround allows for 20% greater linear excursion than standard surrounds
    Stitched-in tinsel leads handle tons of power
    Custom 10-AWG nickel plated push terminals
    Venturi-effect cooling design
    Frequency Response: 20-250 Hz
    Sensitivity: 86 dB
    Rockford sub, generally decent from what i've heard.
    Cerwin-Vega Vega154 - 15" Subwoofers - Sonic Electronix
    15 Dual 4 ohm Vega Series Subwoofer
    Power Handling:
    • Peak: 400 watts
    • RMS: 200 watts
    Mica filled polypropylene cone woofer
    Red rubber surround
    Bumped back plate with vented pole piece
    Woven tinsel leads
    2" Voice coil
    Sensitivity: 88 dB
    Not sure on this, any experience with this brand?
    PowerBass M-154D (m154d) - 15" Subwoofers - Sonic Electronix
    15" Dual 4 ohm M Series Subwoofer
    Power Handling:
    • Peak: 850 watts
    • RMS: 425 watts
    4 Layer, non-pressed paper DDC (Dynamic Damping Coating) finish cone
    Large roll santoprene surround
    Massive motor structure for high power handling and maximum output
    Black emissive coated backplate and pole piece dome shaped to maximize air flow from the vented pole piece
    Chrome push terminals to guarantee optimal power transfer from the amplifier to the subwoofer
    Rubber mounting gasket allows an airtight seal to eliminate bass robbing air leaks
    BASV specially designed resign coated high temperature voice coils ensure accurate linear excursion and high power handling while maximizing thermal hear dissipation
    220 oz Motor structure
    Frequency response: 22-400 Hz
    Sensitivity: 92 dB
    Seems like a poor quality sub because it's made of paper, right?
    15" Single 4 Ohm Frequency Series Subwoofer
    Power Handling:
    FLI Audio FF15-F2 (ff15f2) - 15" Subwoofers - Sonic Electronix
    • Peak: 1200 watts
    • RMS: 400 watts
    • Minimum input: 200 watts
    Impedance: 4 Ohm
    One piece absorbing polypropylene cone with FLI EYE technology
    Heavy roll butyl rubber surround
    New rubber gasket design
    Dual spider for smoother movement and greater linearity
    Enhanced voice coil surround
    Nickel plated spring terminals
    2” Dual layer aluminium voice coil
    52 Oz Ferrite magnet is 5-1/2" in diameter and 1" thick
    Y25 Magnet rating
    Frequency response: 20-1,500 Hz
    Sensitivity: 90 dB
    Big magnet, doesn't seem terrible but why such a big frequency range?
    http://www.crutchfield.com/p_2067C10...04.html?tp=111
    then there's always a deal like this
    10" CompVR Component Subwoofer
    Power Handling:
    • Peak: 800 watts
    • RMS: 400 watts
    Dual 4 ohm model
    Inverted Structural Dome Polymineral Injection Molded Cone: Remains rigid, and lowers distortion
    Rear Cone Brace: Offers unmatched strength and resistance to deformation
    Ribbed Santoprene Surround for Linear Cone Motion
    Silver-Coated Stamped Steel Basket
    Stitched Surround: Ensures the cone and surround won't separate, even under the highest loads
    High-temp Polyimide Film Voice Coil Former
    Dual Ultra-Length Voice Coils
    Perimeter Venting
    Sleeved High-Power Tinsel Lead Wires
    Spring Loaded Nickel-Plated Terminals
    Buy one get one free
    Plan would be to wire all setups for a 2 ohm load on some cheap amp.
    <brandonl2000> LMAO D!!
  2. #2 Re: Thoughts on cheap subs?
    GT Level Member Robroy04gtpcompG's Avatar
    ca
    you could get a hammer and some wire cutters for pretty cheap! oh yeah, don't forget some cheap gloves too.
    haha, just kidding.
  3. #3 Re: Thoughts on cheap subs?
    Kansas
    Out of all of those id chose the P2
    SOLD 1999 GT Silvermist TS
  4. #4 Re: Thoughts on cheap subs?
    ca
    i've heard those p2's, and for the price, they sound pretty good!
  5. #5 Re: Thoughts on cheap subs?
    swift current,sask.
    yup, the rockford is going to be the best choice out of all of them.
  6. #6 Re: Thoughts on cheap subs?
    ca
    i just got all of my stereo equipment out of my truck that the oxycontin girl totaled, and i now have 2 12" J L Audio w2 d2v2 subs, and a two month old amp for them that i am going to put into the GTP. i need to get a new box, as i take the GTP snowboarding. does anybody have a sideways sub setup in their car?
  7. #7 Re: Thoughts on cheap subs?
    swift current,sask.
    With that type of setup, you are going to loose a lot of your volume due to the way the sub is firing. Towards the trunk lid is the best.
  8. #8 Re: Thoughts on cheap subs?
    MO
    i guess i should also double check my thought process for wiring this. I'm planning on leaving the stock head unit, and since voltage is what's important for an audio signal, shouldn't i be able to wire in parallel with the monsoon amp input? that way they're both drawing the same signal at the same voltage?
  9. #9 Re: Thoughts on cheap subs?
    ca
    Quote Originally Posted by whiney View Post
    that's what i was thinking. i will just do one 12 and bridge the amp. i'll put the other 12 in my work truck. i like it!
    zr1vette, you want the power for your amp that will be powering the subs to come straight from the battery, with an inline fuse close the battery.
  10. #10 Re: Thoughts on cheap subs?
    swift current,sask.
    Quote Originally Posted by Robroy04gtpcompG View Post
    Right, cause the monsoon amp would have insufficint size of wire to power another amp. So you will have to run wire from your battery to the trunk.
  11. #11 Re: Thoughts on cheap subs?
    MO
    if you guys read correctly, i'm not talking about amp power. I'm talking about audio signal.
  12. #12 Re: Thoughts on cheap subs?
    swift current,sask.
    Quote Originally Posted by ZR1Vette09 View Post
    Ok, no we got that cleared up, get yourself a line level converter an you will be set.
  13. #13 Re: Thoughts on cheap subs?
    MO
    something like this? Scosche LOC80 2-channel line output converter at Crutchfield.com
    do i have to hook it up straight to the HU or can i put it back just in front of the monsoon amp? Probably noise would become an issue if I put it too far back, right?
  14. #14 Re: Thoughts on cheap subs?
    swift current,sask.
    Nope i did mine with the bose amp so similar situation, and had no issues with noise. But remember it needs to be the amplifed signal otherwise it will make little to no noise at all.
  15. #15 Re: Thoughts on cheap subs?
    MO
    Help me out with that. not catching what you mean.
  16. #16 Re: Thoughts on cheap subs?
    swift current,sask.
    Because the converter uses the signal from the amplifer to the speaker, not from the deck to amplifer. The signal has to be amplifed for the converter to work properly easy way to put it.
  17. #17 Re: Thoughts on cheap subs?
    MO
    ohhh ok. i gotcha. I haven't ever looked, are the lines from the amps to the speakers RCA's? Is that link that I posted the right part?
  18. #18 Re: Thoughts on cheap subs?
    MO
    cheapest price on that rockford i've found is 100 bucks from millionbuy.com. I've bought from them before and it went smoothly. Just gonna hold out a while and see if i can do better
  19. #19 Re: Thoughts on cheap subs?
    swift current,sask.
    That is the right part, what about the rca's? Not following you.
  20. #20 Re: Thoughts on cheap subs?
    MO
    just wondering how i hook in that part. splice the wires?
  1. Tire thoughts.
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 08-03-2015, 12:21 AM
  2. What are your thoughts on SLP
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 04-11-2009, 02:07 PM
  3. thoughts
    By 99gpse in forum Off Topic Discussion
    Last Post: 02-23-2009, 02:34 AM
  4. thoughts on headlights
    By 99gpse in forum General Tech Discussion
    Last Post: 12-19-2008, 01:03 AM
  5. Well I Need Some Thoughts...
    By SlickGTP in forum Off Topic Discussion
    Last Post: 01-14-2008, 01:28 AM
