Thread: Bad Radio Reception
Results 1 to 11 of 11
  1. #1 Bad Radio Reception
    GT Level Member hester21289's Avatar
    Monroe, GA
    My 2000 GT doesn't pick up but a few radio stations (clear enough to listen to)
    Does anyone know what I could do to boost reception.
    BTW I have 5% tint on the rear window, would that be a factor in the bad reception??? The antenna is on the rear glass isn't it???
    Thanks
    2004 Chevrolet Impala SS
  2. #2 Re: Bad Radio Reception
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    yeah the antenna is on the back glass...
    do you have oe stereo or aftermarket? if aftermarket, you need to make sure the wire for the power antenna is connected... there's a factory booster in the roof.
    if your tint has metal film in it, yeah it could cause a problem
  3. #3 Re: Bad Radio Reception
    Saraland Alabama
    more than likely the tint is the issue, whoever the braindead engineer was that came up with the back glass he should have seen the previous glass antennae fiasco (in the late '70s it was in the windshield, and you couldn't pick up jack)
  4. #4 Re: Bad Radio Reception
    Monroe, GA
    Is there any type of external antenna that I could use, that wouldn't look gay???
  5. #5 Re: Bad Radio Reception
    SW Chicago Suburbs
    Quote Originally Posted by hester21289 View Post
    depends on what your definition of ghey is.... lol
    you could drill and mount an oe style antenna on the rear fender, like the early '97's had.
  6. #6 Re: Bad Radio Reception
    Monroe, GA
    Quote Originally Posted by Toasty View Post
    Thats what I mean, it looks out of place.
    I saw an newer Impala, like a 02', with a small antenna on the outside of the rear glass, I don't know if it was OEM or not, but it didn't look too bad.
  7. #7 Re: Bad Radio Reception
    SW Chicago Suburbs
    that's likely for aftermarket XM, etc
    you could try and mount an early 97 style antenna in the trunk or under the car, but not sure what the reception would be
  8. #8 Re: Bad Radio Reception
    Monroe, GA
    Alright, thanks for the help/suggestions.
    I think Im just gonna get sat. radio, don't really want to waste any money for the am/fm junk we have around here anyways.
  9. #9 Re: Bad Radio Reception
    GTP Level Member David99GTP's Avatar
    Florida
    I have 2% tint and no issues with reception. My problem occured right after upgrading my plugs, wires, coil packs. I heard plugs can cause this issue.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  10. #10 Re: Bad Radio Reception
    Saraland Alabama
    if they aren't resistor
  11. #11 Re: Bad Radio Reception
    Florida
    Hmmm maybe thats my problem.
    1999 GTP
  1. adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    By s1795so2 in forum How To Write-Ups/Tech Tips
    Last Post: 04-19-2010, 07:10 PM
  2. Radio is effed up
    By FoSHO99 in forum Audio, Security & Visual Electronics
    Last Post: 04-01-2010, 03:12 AM
  3. How to make a nicer aftermarket radio mounting kit. [*]
    Last Post: 02-18-2008, 10:45 AM
