Thread: Inline fuse / fused power distribution block
Results 1 to 20 of 29
Slueth66 Inline fuse / fused power... 03-16-2010, 08:44 PM
Slueth66 Re: Inline fuse / fused power... 03-16-2010, 08:50 PM
CTKGP09 Re: Inline fuse / fused power... 03-16-2010, 09:15 PM
Slueth66 Re: Inline fuse / fused power... 03-16-2010, 11:25 PM
CTKGP09 Re: Inline fuse / fused power... 03-17-2010, 07:12 AM
Slueth66 Re: Inline fuse / fused power... 03-17-2010, 08:08 PM
CTKGP09 Re: Inline fuse / fused power... 03-17-2010, 08:11 PM
Slueth66 Re: Inline fuse / fused power... 03-17-2010, 08:50 PM
CTKGP09 Re: Inline fuse / fused power... 03-17-2010, 09:14 PM
CTKGP09 Re: Inline fuse / fused power... 03-18-2010, 09:38 PM
Slueth66 Re: Inline fuse / fused power... 03-17-2010, 09:46 PM
CTKGP09 Re: Inline fuse / fused power... 03-17-2010, 09:48 PM
Slueth66 Re: Inline fuse / fused power... 03-17-2010, 10:26 PM
Slueth66 Re: Inline fuse / fused power... 03-18-2010, 04:30 PM
Timmi Re: Inline fuse / fused power... 03-18-2010, 04:46 PM
CTKGP09 Re: Inline fuse / fused power... 03-18-2010, 07:02 PM
Slueth66 Re: Inline fuse / fused power... 03-18-2010, 07:37 PM
CTKGP09 Re: Inline fuse / fused power... 03-18-2010, 07:50 PM
MrPhotographer06 Re: Inline fuse / fused power... 03-18-2010, 09:30 PM
Slueth66 Re: Inline fuse / fused power... 03-18-2010, 08:51 PM
98GTPCALGARY Re: Inline fuse / fused power... 03-19-2010, 01:33 PM
Slueth66 Re: Inline fuse / fused power... 03-19-2010, 03:58 PM
TheOtherNick Re: Inline fuse / fused power... 03-19-2010, 06:24 PM
Slueth66 Re: Inline fuse / fused power... 03-19-2010, 09:02 PM
TheOtherNick Re: Inline fuse / fused power... 03-19-2010, 09:52 PM
Slueth66 Re: Inline fuse / fused power... 03-19-2010, 11:38 PM
98GTPCALGARY Re: Inline fuse / fused power... 03-19-2010, 11:53 PM
Slueth66 Re: Inline fuse / fused power... 03-20-2010, 12:12 AM
MrPhotographer06 Re: Inline fuse / fused power... 03-18-2010, 09:41 PM
  1. #1 Inline fuse / fused power distribution block
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    So im installing a massive 0 gauge dual amp kit in my gp, and it has a inline fuse and a fused distribution block. Do i need to use both of them? The inline fuse is 250 amp, while the distribution block has 2, 100 amp fuses. Im running a 1200 watt amp, and a 1000 watt class d amp and not sure if i need to install the inline fuse if using a fused distribution block.
  2. #2 Re: Inline fuse / fused power distribution block
    Nov 2008
    Iowa
    Alrighty, thanks for the help. This 0 Gauge install has been whoopin my A$$. probably should of went smaller but hey, it was only 60 bucks shipped.
  3. #3 Re: Inline fuse / fused power distribution block
    Willoughby, Ohio
    yeah good luck hiding that wire ha, i shoved two 4 guage wires both down my passenger side and they were hidden nicley, just took a little time...
  4. #4 Re: Inline fuse / fused power distribution block
    Nov 2008
    Iowa
    You should ask the rubber grommet how he feels about the whole situation. o wait, i just ripped it in half and threw it away cause it was being a pain in my a$$. it just looks like there is a snake under my carpet
  5. #5 Re: Inline fuse / fused power distribution block
    Willoughby, Ohio
    nice, i think you pissed off the grommet...
  6. #6 Re: Inline fuse / fused power distribution block
    Nov 2008
    Iowa
    so, i got everything installed, and it sounds great, but at volumes below 15, it sounds like im playing a recording of my car idling. The feedback im getting is horrible. Any help?
  7. #7 Re: Inline fuse / fused power distribution block
    Willoughby, Ohio
    you have engine noise, do you have an aftermarket deck? or LOC?
  8. #8 Re: Inline fuse / fused power distribution block
    Nov 2008
    Iowa
    I got an alpine 9887, its probably just my horrible ground. any metal in the trunk good? i grounded it to the metal at the back of the trunk that the rear seat hooks into.
  9. #9 Re: Inline fuse / fused power distribution block
    Willoughby, Ohio
    ok i know pioneers have the problem of the RCA grounds in the deck comming apart, in which case they must be resoldered. you can also use a jumper wire to all the RCA jacks in the back of the deck. whatever you do there is definatley a bad ground
  10. #10 Re: Inline fuse / fused power distribution block
    Willoughby, Ohio
    Quote Originally Posted by CTKGP09 View Post
    ya thats what i meant by the jumper wire i mentioned, my bad i forgot to mention the sticky about it...
    and my friends pioneer RCA grounds in the deck came loose and he had it resoldered, but that was a pioneer
  11. #11 Re: Inline fuse / fused power distribution block
    Nov 2008
    Iowa
    I have also been wondering about my subwoofer. I'm running a Rockford fosgate P3 ( Dual 4 ohm) in a q-logice type 2 sealed box that is facing the rear of the trunk. Its powered at 500 rms at 2 ohms by a 1000 watt kenwood amp. To me it sounds weak, almost no bass unless i got it cranked pretty loud. i have never heard one 12 inch sub running around the same power to compare it to. I'm worried the amp is not running full potential, because i had to open it up a few times to attach a ground, since the kid before me snapped off the terminal. This might be a dumb question, but can someone try to get me in the ball park on what i should experience from 1 12 inch woofer.
  12. #12 Re: Inline fuse / fused power distribution block
    Willoughby, Ohio
    wire your sub into parrallel, and tune your amp, and tweek the settings on your deck
  13. #13 Re: Inline fuse / fused power distribution block
    Nov 2008
    Iowa
    thanks, got the gain set pretty low do to the 4 volt pre amp outputs. im gonna mess with it some more tomorrow.
  14. #14 Re: Inline fuse / fused power distribution block
    Nov 2008
    Iowa
    So i changed up my ground, and still get horrible feedback. I can hear my hids turn on, the ballasts fire up, my engine idle, pretty much anything, and its loud. I even get feedback when i unplug the rcas from the back of the head unit. Im lost with no ideas....
  15. #15 Re: Inline fuse / fused power distribution block
    Leightion, IA
    Quote Originally Posted by Slueth66 View Post
    I grounded my system (which has 1/0 gauge wire and a whole second battery in the trunk) to the bolts that come off the strut. I have no feedback.
  16. #16 Re: Inline fuse / fused power distribution block
    Willoughby, Ohio
    its the headunit itself, the RCA grounds are probably bad
  17. #17 Re: Inline fuse / fused power distribution block
    Nov 2008
    Iowa
    I hear that's common on pioneers, but im running an alpine 9887 so i wasn't sure. guess its my last hope
  18. #18 Re: Inline fuse / fused power distribution block
    Willoughby, Ohio
    if the RCAs are not connected and you are still gettin engine noise, then its the head unit. resolder the grounds or have someone do it, then make sure its reinstalled properly and not vibrating against any metal or anything that would make the problem happen again
  19. #19 Re: Inline fuse / fused power distribution block
    GT Level Member MrPhotographer06's Avatar
    Fort Bragg, NC
    i didnt wanna start a new thread, but did you run your power wire to the power input at the top of the engine bay fusebox?
  20. #20 Re: Inline fuse / fused power distribution block
    Nov 2008
    Iowa
    is this the fuse on the back of the head unit? mine has a 10 amp fuse on the back that i checked today, which it was fine. if this is the one you are talking about im not sure. For mod in the sticky, will 12 gauge speaker wire work to wrap around the rcas? and if this doesnt work ill probably just give up for awhile.
  1. fuse block ?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2009, 01:09 AM
  2. 04 Grand Prix Fuse Block map
    By btempelman in forum General Tech Discussion
    Last Post: 03-15-2009, 03:38 PM
  3. 04 GP Fuse Block Map - Power Window Circuit Breaker
    Last Post: 03-15-2009, 12:24 PM
