Thread: Inline fuse / fused power distribution block
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #1 Re: Inline fuse / fused power distribution block
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    Yes, I agree, it has got to be a bad ground somewhere. also, where did you run your RCA's are they with the power wire? because I have been told by Rockfords Audio Tech's that you should not run the power wire in the same area as the rca's (they "backfeed" sort of thing) so run your power wire on one side of the car, and your RCA's and Remote wire on the other side.
    For the lack of sound from your sub, If I read right, it is a DVC? how do you have it wired?
    98' GTP, 18's, BMR Adjustable Forward & Rear Lateral Arms, BMR Tubular Trailing Arms, Intense PCM, CAI, drilled rotors, 5% Tint all around
  2. #2 Re: Inline fuse / fused power distribution block
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    so today, i grounded the rca's to the headunit, as done in the sticky, and no luck again. I got the power and rca ran on different sides of the car, i even tried changing the headunits ground to whre i grounded the amp and still no luck. guess im gonna have to look into a ground loop isolator
  3. #3 Re: Inline fuse / fused power distribution block
    Charles City, IA
    We could slap my head unit in to see if the issue is in the head unit.
    SMGPFC Two Nipple General
  4. #4 Re: Inline fuse / fused power distribution block
    Nov 2008
    Iowa
    i got one more thing up my sleeve, me and the ole man are gonna look at it tomorrow, and if it doesnt work, we will try that when i get back for summer. my headunit is fairly new.
  5. #5 Re: Inline fuse / fused power distribution block
    Charles City, IA
    what you going to try?
  6. #6 Re: Inline fuse / fused power distribution block
    Nov 2008
    Iowa
    just gonna test more grounds. ground the headunit right to the firewall or somewhere under the dash, hopefully making it more like the ground in the trunk, hopefully getting rid of some noise. dont know why i didnt try it first. if i wasnt such a perfectionist i wouldnt even notice the noise after awhile.
  7. #7 Re: Inline fuse / fused power distribution block
    Feb 2009
    Red Deer AB
    ya, you would... Every time you turn down your music to talk or answer the phone, you dont get use to it!
  8. #8 Re: Inline fuse / fused power distribution block
    Nov 2008
    Iowa
    Is it bad that my days are ruined just thinking about the feedback and how awful it sounds, as i sit in my basement pondering the cause. And whats worse is i havent been driving my car since xmas, and wont be until summer break. Curse you college and annoying feedback!!!
  9. #9 Re: Inline fuse / fused power distribution block
    GT Level Member MrPhotographer06's Avatar
    Fort Bragg, NC
    Thats the best spot.
    Thanks, thats what i did today, and i wanted to make sure it was safe.
  1. fuse block ?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2009, 01:09 AM
  2. 04 Grand Prix Fuse Block map
    By btempelman in forum General Tech Discussion
    Last Post: 03-15-2009, 03:38 PM
  3. 04 GP Fuse Block Map - Power Window Circuit Breaker
    Last Post: 03-15-2009, 12:24 PM
