Thread: reomve or keep 4" speakers in rear deck?
Results 1 to 20 of 20
  1. #1 reomve or keep 4" speakers in rear deck?
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    Im planning on running a 4 channel amp to the rear and front, but not sure if i should just leave the 4 inch speakers installed and not powered, or remove them? I have read something about it creating a bandpass like enclosure, but am still not sure if that would be a good thing or bad thing.
  2. #2 Re: reomve or keep 4" speakers in rear deck?
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    are you upgrading the other speakers? or just powering the stock ones? and are you running subs? If you have subs in the trunk, and you are not "using" the 4" speakers take them out, it will sound good for the subs. the same as if you open the center pass thru in your seat
  3. #3 Re: reomve or keep 4" speakers in rear deck?
    swift current,sask.
    Quote Originally Posted by 98GTPCALGARY View Post
    If you have sub's in a gp, you NEED to open up the pass-thru or it sounds like s**t aah take them out and just keep your 6x9's works fine for me.
  4. #4 Re: reomve or keep 4" speakers in rear deck?
    Nov 2008
    Iowa
    Thanks for the help guys. I replaced all the stock speakers with infinites, so i will just remove the 4" ones and try to sell them. Be kinda pointless to buy another amp just to power them. Im also running 1 rockford fosgate p3 in a qlogic type 2 sealed box at 500rms @ 2 ohms but sounds kinda weak, probably because of my cheap kenwood amp that i had to fix a few times, but hey, it was FREE
  5. #5 Re: reomve or keep 4" speakers in rear deck?
    Nov 2008
    Iowa
    will do, i got a lot of crap to get done to my baby, with a short spring break, hope it all goes swell.
  6. #6 Re: reomve or keep 4" speakers in rear deck?
    Feb 2009
    Red Deer AB
    agreed, subs face the back of the car sounds way better!
  7. #7 Re: reomve or keep 4" speakers in rear deck?
    Feb 2009
    Red Deer AB
    well then you need bigger speakers, and amps..lol
  8. #8 Re: reomve or keep 4" speakers in rear deck?
    Feb 2009
    Red Deer AB
    lol, I have about $900 into my setup, and thats including the $600 dvd player, oh, I forgot my wires and cap, so ya maby $1000. and this setup is running about 133 db
  9. #9 Re: reomve or keep 4" speakers in rear deck?
    Feb 2009
    Red Deer AB
    boring. lol
  10. #10 Re: reomve or keep 4" speakers in rear deck?
    Feb 2009
    Red Deer AB
    Mach5audio!!! ha, My old nabour sells them, he set up a ford f-250 ext-cab with 8 12's and a buttload of components, it is sick!
  11. #11 Re: reomve or keep 4" speakers in rear deck?
    Feb 2009
    Red Deer AB
    what you mean "for you"? lol
  12. #12 Re: reomve or keep 4" speakers in rear deck?
    swift current,sask.
    Hey, how does that monster sound in a car? The mach 5 one?
  13. #13 Re: reomve or keep 4" speakers in rear deck?
    Feb 2009
    Red Deer AB
    ah, gotcha
  14. #14 Re: reomve or keep 4" speakers in rear deck?
    swift current,sask.
    Humm that may be a fun little project...
  15. #15 Re: reomve or keep 4" speakers in rear deck?
    swift current,sask.
    Yes judging from the pita factor its going to be, i may just go for a 15 then.
  16. #16 Re: reomve or keep 4" speakers in rear deck?
    swift current,sask.
    I like that idea, eventually i wanna do 8's in the deck and like you said 2 15's.
  17. #17 Re: reomve or keep 4" speakers in rear deck?
    Feb 2009
    Red Deer AB
    subs in the doors can be great, but we already have heavy doors, that want to fall off without the extra wieght.
  18. #18 Re: reomve or keep 4" speakers in rear deck?
    Nov 2008
    Iowa
    Ever seen these?
    Elemental Designs
  19. #19 Re: reomve or keep 4" speakers in rear deck?
    Nov 2008
    Iowa
    The reviews say there alright, but i got no idea, i just think there cool cause there made in Iowa.
  20. #20 Re: reomve or keep 4" speakers in rear deck?
    Feb 2009
    Red Deer AB
    I've got a four door, smaller doors
    Junkyards are full of hinges anyways.
    http://creativesound.ca/pdf/TRIO8.pdf
    10 Lbs plus the box... which will easily be 10-20 lbs.
    That'll make for some nice solid doors.
    Like the old days
    Skip the box, Use some fiberglass. Easy to "fit the space" and less lb's
  1. ported rear deck
    By abuckley1290 in forum Audio, Security & Visual Electronics
    Last Post: 12-09-2009, 03:05 AM
  2. stock bose speakers putting in a dvd deck
    By ssheibels8512 in forum Audio, Security & Visual Electronics
    Last Post: 08-26-2009, 04:57 AM
  3. 4" Rear Deck Speakers
    By Aceoage in forum Audio, Security & Visual Electronics
    Last Post: 09-06-2008, 09:04 AM
  4. 4" speakers in the rear deck....
    By halfwit in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2008, 05:40 AM
