Thread: Relocate trunk open button
Results 1 to 12 of 12
  1. #1 Relocate trunk open button
    Michigan
    I want to put my trunk open button in the ashtry from the glove box, and relocate the cigarette lighter somewhere hidden, but i dont know how to move the trunk open button to the ashtray in the first place, anyone know how i would go about doing this?
  2. #2 Re: Relocate trunk open button
    Wooster, Ohio
    wow, then i dont think you should try it.... remove button, put in ashtray, run wires to button in ashtray
  3. #3 Re: Relocate trunk open button
    Michigan
    thanks douche your helpful lmao
  4. #4 Re: Relocate trunk open button
    Wooster, Ohio
    i'm very helpful when people ask useful questions, if you don't know how to do something as simple as this, you shouldn't be trying. Its kind of a, so you don't ruin a perfectly good car thing
    your just lucky i was the first to post before kawa and bluegtp, good luck
  5. #5 Re: Relocate trunk open button
    Michigan
    I have a general idea, i just wanted to know how to get the button out of the original place
  6. #6 Re: Relocate trunk open button
    Look at it?
    Thats how you get anything apart.
    "How do you pull an engine?"
    Remove everything attached to it and pull... VERY simple concept but it comes down to your practical skills and common sense.
    If you dont have those two tools, you shouldn't even own any tools in the first place.
  7. #7 Re: Relocate trunk open button
    Michigan
    Is everyone on this website an arrogant stuck up ***** or just you two? It was a question that could have been answered without being a smartass. Or not replied to at all. Get over yourselves.
  8. #8 Re: Relocate trunk open button
    Wooster, Ohio
    lol, good luck on here, were nothing compared to most
  9. #9 Re: Relocate trunk open button
    Its when people like you, do their own brakes I become concerned.
    If you can't figure out the relocation of a single switch, how are capable of changing pads and rotors and torquing everything properly?
    That becomes a real safety hazard for everyone.
  10. #10 Re: Relocate trunk open button
    GT Level Member tylerbinski's Avatar
    Canada
    What is the point?
    so people can't just pop your trunk when they break into your car and steal your stereo?
    Something I never got around to is wiring up the trunk pop so that it only works when the key is in the ignition.. or installing a disable switch, or connecting to my alarm so when it is armed the switch won't see power.
    - you did ask a sorta silly question.. make an effort first then ask.
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  11. #11 Re: Relocate trunk open button
    pull the lighter out, put a plate over where it used to be and then mount the button there. rewire it from its stock location and then do the same thing with the lighter.
    how hard is this?
  12. #12 Re: Relocate trunk open button
    West Side Michigan
    I like leaving it in the glove box because then you can lock the glove compartment therefore nobody has access to the trunk except you.
    Pretty simple just take the wires that are connected to the trunk button and relocate them wherever you like. You could probably use the stock button or find a new one. Pretty much the same concept with the cig lighter. Just be careful because the wires that are from the cig lighter are LIVE wires and have a full 12v going to them (I thinkg?..)
    Good luck!
  1. bbv open air
    Last Post: 08-17-2009, 04:33 AM
  2. ughhh, trunk wont open!
    By black98gt in forum General Tech Discussion
    Last Post: 03-12-2009, 08:23 PM
  3. IAT relocate?
    Last Post: 10-23-2008, 10:23 PM
  4. Relocate HUD switch [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 01-27-2008, 07:03 PM
