Thread: IAT relocate?
Results 1 to 9 of 9
  1. #1 IAT relocate?
    Donating Users
    Plainfield, IL
    ok so i see on intense racing they sell an extension for the iat sensor to be relocated for FWI's....will moving the sensor closer to the fenderwall or in the fenderwall after installing a FWI make anytype of difference?
  2. #2 Re: IAT relocate?
    GrandPrix Junkie FastKatt's Avatar
    Feb 2008
    Rkrd, IL
    Your car will see closer to REAL Air Temps vs. HOTTER Readings it sees now
    These cooler more accurate temp readings will let you see more timing advance
    It's safer than using a resistor on the IAT to "fake" cooler air because your car will still be basing the timing advance on real temps & not blow up your car adding timing it shouldn't
    No trees were destroyed for this message.
    However, a great number of pixels were extremely inconvenienced.
    2004 Grand Prix Comp-G GTP Mod List - MySpace
  3. #3 Re: IAT relocate?
    I live here. UR LOSN's Avatar
    Rockford, IL
    ^^^^agreed.
  4. #4 Re: IAT relocate?
    Donating Users
    Plainfield, IL
    what resistor should i use and how do i put it in?
  5. #5 Re: IAT relocate?
    Barksdale AFB, LA
    Quote Originally Posted by iamwhutiam003 View Post
    Did you not read what he said?
    Quote Originally Posted by FastKatt View Post
    2009 Subaru Impreza WRX STI
  6. #6 Re: IAT relocate?
    Feb 2008
    Rkrd, IL
    Wow,...
    I guess I shouldn't even had said anything...
    Just,... Wow
    Side Note: Jacob, hit my cell when you get a chance
  7. #7 Re: IAT relocate?
    Donating Users
    Plainfield, IL
    my bad im tired i read it the opposite way that resistor was safer....ok thanks...every one is so hostile around here lol...so all in all is it safer to just leave it in the stock location...will i even feel a difference if i move it? or not enough of one to go through with it?
  8. #8 Re: IAT relocate?
    Feb 2008
    Rkrd, IL
    Well, it's safer to leave it, but it's not unsafe to use the relocate and take full advantage of your computers ability to adjust for changes in air temp
  9. #9 Re: IAT relocate?
    Donating Users
    Plainfield, IL
    ok thanks man
  1. Relocate HUD switch [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 01-27-2008, 07:03 PM
