Re: Getting new subs want opinons.
MrTube
matt : what does that mean exactly?
You have speakers that add delay them selves or something?
and on the storage space note, to alot of people storage is just as important and often more important then sound. My car is not a show car, its a work car. And the trunk will remain 80% empty even after I do work to it for sound.
He's poking at your speaker selection :)
My opinion is that you need two or three cheap subs or one to two nicely designed subs. Personally, I like my trunk space. I'm going to be fabricating one day so that I can gain some of that back. I don't like a box + 2 speakers taking up space the way they do.
Yea, hard to get the mids and tweeters as far from you as the subs in the trunk tho. A simple DSP would work but does anyone offer one? Id have to assume yes
I800 : yes, I know he was. However it was not my car when it happened, it was my best friends. And again, UNDER $500 for an entire system that was sooo much better then stock.
I had a $4500 system in my truck, if you check retail A/D/S/ prices from the late 90s + the $600 eclipse head.
BTW I800 check your PM'S :)
Turning to the SQ side! Need suggestions - Page 2 - DIY Mobile Audio
OP!!!!
Read the above :) I won't get into what they're speaking about but you can definitely research the site to find out more concerning speaker specs. In the end, you gotta be the fisherman.
After I finish a few things in my own project I'll be looking to go ported with my R12's. My DSP is built into my cda-9887. Check my links and you can see photos of my alpine MrTube. It's only designed for 3-way. Pioneer plans on releasing a 1k h/u from their Premier replacement line. It is 4-way w/30band R/L EQ :D I need the 4-way for my rear fill implementation. They also moved the jog dial for the iPod to the remote. It's a beautiful deck. You can buy the Japan version for ~1200 and it contains a 6 channel 50w amp. The Euro version doesn't have the amp.
Oh ya...tweeters aren't that big of a deal when it comes to path length distance. I'd say shoot for 15 or 20 degrees off axis(depending on tweet, but reflections make tweets go crazy). They respond much better to attenuation while mids respond better to time alignement. I'm thinking of going with kicks for mids and tweets on the upper door towards the a-pillar; about head level for me. Subs don't need t/a because their wave lengths are typically larger than the vehicles cabin.
I'd also like to point out that passive cross overs tend to vary in response due to temperatures and load values. Active DSP cross overs = gewd times and much more consistant. Some of the best speakers maintain passive x-overs but they're dealing with home audio. The correct way to build a passive in a vehicle MUST be based on specific cabin design in relationship to speaker placement too. Europeans have a thing for starting out active during tuning and building passives based on the parameters they finalize. It helps with k.i.s.s.
I800C0LLECT
Well I would actually say that the delay was caused with the sub not blending properly with the mid-bass up front. Many people state that theory will explain why subs do not need T/A. However, I have noticed a difference with mid-bass interaction based on delay.
Thats retarded. How you can you claim the BIGGEST waves of them all would be least affected by phase? They'd be the most likely to create MASSIVE dead spots due to cancellation.
The reason kick panels are so great is because path length is so important with the wave lengths of ~300hz up to about 1500hz. We want the mids as far from the listener as possible in a vehicle. Another benefit is the proximity of the tweeter to the mid itself allowing it to blend better and create a single point source. This is a must when using passive cross overs imo. In the end, these two advantages takes care of the predominant issues of installing within your vehicle.
Why? If all the speakers are the same distance from the LP, then you win.
Learn how to design a nearfield speaker and you'll see why this whole "OMG PUT THEM FAR AWAY" idea is a load of crap.
WTF do you think they do when they make studio monitors? Cry since they're nearfield speakers and compromise the design so they'll work placed far away where no one will place them since their own intended use is for nearfield?
Funny....
There's obviously a whole world of hurt associated with car installs but I'd rather steer away from defraction and reflection issues that are inherent to doors and dashboards. I will say that putting the tweeter as close as possible to a window displaces reflection to the 17khz and above. It changes based on the proximity to the window due to real world wave lengths but it's a quick tip for when looking at tweeter locations.
And the "pros" claim they actually use the window to reflect sound properly... :rolleyes:
I'll take a look at the rest when i get off work...:th_tongue2:
oh stop, we all know you don't work :)
BTW, I800 , id like to point out that IMO passive crossovers belong in the garbage. But you already knew my thoughts on those.
ON my last setup I noticed if it was near 0F outside when I would listen to music I would have close to no highs, never figured out if it was from the electrolytics in the crossovers being frozen, or if it was the ferrofluid in the tweeters being thick. I forget to look into that before selling the truck. Kinda a moot point, but you bringing up passive crossovers made me think of it :)
hrmmm.
Here we go again ;)
matt5112
Maybe you read into that differently than I had hoped? What I'm saying is that the frequencies your mid produces react very well to T/A. Your sub does not. When tuning to bring about a transparency between the mid-woofer and sub-woofer the stage can become confusing if your mids aren't tuned properly. Although a double kick is pronounced in the sub-range the roll off is as high as 800hz. In this instance if your mid isn't tuned properly then localization will be prevalent and the mid will not pick up where the sub left off.
The cancellation would be attributed to installation and x-over points. How about this...is it easier to manuever two cars next to each other at the same time or one at a time? Leave the sub alone. T/A mids to match distances. Attenuate and EQ for transparency.
This has nothing to do with speaker design or near field presence. The relationship of this installation practice is proportionate to the actual wave lengths. Tweeters will not benefit from kicks; only the frequency range I specified which is found in your mid.
There you go taking experience from home audio again :)
Not all of them. Most of them talk a lot of trash and play mind games because they don't want psychoacoustics to ruin their scores. When they're making those claims they're referring to an installation that is designed around the issue of reflections. Instead of fighting them, they try to work with them instead.
btw. Besides the delay another problem i've noticed with all setups including the pricey a/d/s/ one was trying to get the subs in phase with all drivers. This obviously gets even worse if you have rear-fill.
btw,
you guys think maybe we should take this to our own thread? We can call it the mrtube,I800collect and Matt thread, :)
MrTube
btw,
Might keep this one a little cleaner... go for it:th_thumb-up:
Sorry did I see you say install speakers so that their phase is naturally in line?
Read further back at my suggested setup... tell me that a midwoofer will be easy to time align when it goes down to 50 Hz and the sub won't be?
Tell me why all home audio receivers have the "distance" option for all the speakers INCLUDING the subwoofer. :th_jester:
Source/reasoning?
My counter argument is this:
http://www.imuso.co.uk/images/Legacy...ct/ST01053.jpg
Lets take a look at the manual...
http://www.krksys.com/manuals/rpg2_manual.pdf
Installing Your Monitors
The close-field monitor, by definition, reduces room interaction. This can be compared to the conventional stereo configuration or the large monitor arrangement in a recording studio where sounds emanating from the monitor or reflecting off ceilings, walls, and floors greatly affect the sound quality. By shortening the path to the ear, the close-field monitor offers a tremendous amount of flexibility, allowing the sound to become less susceptible to differing room conditions. The ability to adjust the high frequency characteristics is equally important to help compensate for room irregularities and achieve the best performance.
Close-Field Configuration – In a control room situation, the monitors are often times placed on the meter bridge or in a close-field listening position. Initial placement starts by measuring out a simple equilateral triangle (all three sides equal in length) with the apex at the center of the listening position (as shown in Figure 1) as an “overlay” for the stereo installation. In this configuration, the Left and Right monitors are each placed at a 60° angle, equidistant from the listening position.
Mid-Field Configuration – This configuration is similar to the Close-Field configuration. It is normally used with larger monitors or when the monitors are too large or heavy to be placed on the work surface. This set up has the potential for a larger sweet spot and better spatial imaging. Make sure that the monitor is high enough so that the woofer is not obscured by your mixing surface or studio furniture (refer to Figure 2).
So which one is more easily achievable in a car and more worth while?
You do of course realize that the resulting sound dispersion pattern would be hell on wheels right?
Show me an analysis of the predicted dispersion pattern or did they even think that far ahead?
MrTube
Adjust the phase? Its not that difficult.
You have to do the exact same thing when setting up your sound system in your home. Only difference is, most of the time you can get away with having the sub in front of you.
I800C0LLECT
Yeah... sub size is basically, go as large as you can get away with. There is no logical reason to go for a sub with less surface area since it will have to move further to produce the same SPL and thus do it with more distortion.
But height is a major concern.
I'm not sure what you're suggesting... but tweets sound best when on axis... If you suggest anything other than that, you have no place in audio. :D
They respond much better to attenuation while mids respond better to time alignment.
Perhaps working a little magic you could minimize the use of both?
So you're going to put your mids where they'll be blocked by your own legs and/or any passengers you may/may not have? I see... Perhaps I should put my speakers underneath my seat. :p
So the phase difference at the sub/midwoofer crossover doesnt matter? I think you'll find that you can have MANY issues with that crossover if you get it wrong. This sort of thinking is why 99% of people have ****ty mid-bass.
Passive x-overs are for those who are too cheap to buy more amps or those who are too afraid of being able to change your crossover at the touch of a button.
OR....... if you sell speakers and you wanna make sure your customer doesnt ruin them or have to set them up properly.
In otherwords, the ignorant (and i don't mean that in a negative sense) and the acoustically/electrically-retarded.
IFF you're using completely digital controls, none of this pot controlling the frequency business.
They only do that because they don't want the customer to have to setup the speaker.
Coils inductance won't change much in a house since the temperatures are fairly consistent, unlike a car where it changes all the time.
That means your low pass filters will change based on the coils temperature.
Also the drivers position relative to each other doesnt change in a home audio situation unlike car audio.
And temperature?
And that's pointless because you've already invested in the superior system and then you turn around and waste money on most likely over-priced passive x-over components.
WTF
Honesyly I could care less if you post in this thread, i'm learning as you guys are arguing. Lol
Its more of a healthy debate... :D
Fine debate... Got another question while i'm posting, Where do you figure the "optimal" placing for my tweetes are. I have them cut into the mesh grille's and it just doesn't sound right. So where would you suggest?
adjust the phase? Matt, not all speakers are going to be 180 degrees out of phase with the sub. Its impossible to keep all 4 6 1/2's in phase with the subs. If a speaker is 100 degrees out of phase, how do you fix it? I believe you can do tricks with active crossovers, but they would have to be custom made.
Its also difficult in a house, to keep 5 speakers all in phase with a sub. I had problems with 2.1 on my pc using two a/d/s/ speakers in a corner, one on each wall and a sub. I couldn't get both speakers inphase together with the sub. And if i flipped polarity on one speaker, now it was out of phase with the other speaker. I gave up pretty quick.
Changing the "time alignment" is changing the phase... any decent home audio reciever has "distance" settings which basically control phase of each channel.
All it does is delay different channels by different amounts of time so that the sound arrives at the LP at the same time.
That alone changes the "phase" of the sound waves when it reaches the LP at a given point in time.
In your example, flip the polarity then adjust the time alignment so that at the crossover frequency, they are in phase.
T/A is more than just phase :/ Reflections act as speakers themselves too. This is where an RTA can really help people identify issues due to all the reflective surfaces in a vehicle. Sometimes a 1db decrease from the speaker results in much more because of the reflective areas.
that is true but if the sound is more than one cycle out of phase, how are you going to know?
That's when you bring out the math and start measuring distances between objects vs. speakers in correlation with LP and HP frequencies. Reality: Have I done it? nope. Have I read about it?...yes. Have I witnessed a conceivable difference w/installatino practices?...haven't tried :)
Matt : btw, whats in your car? I'm curious to see your setup if you have pics and or specs.
I hope its not all Pyramid and Kraco stuff :)
just kidding, tho I would like to see what you have setup, and any past stuff you've done, House stuff too.
Imagine the sound is delayed exactly one cycle but in phase.
How will you know?
My setup is pioneer mid and tweets.
I have pics, but theres no point in showing them since its all getting ripped out to make way for some guages. Top swap + cam + headers in the works :)
I'll rework it but mount it on the doors.
Basically a 5.25" midrange with two 7/8" tweets on top of that x'd over at 5K.
Going for some 10" drivers in the doors, still havn't done that yet.
Going to get rid of my damned $10 subs in the trunk... two 12" $10 eD subs on a kW amp means hardcore compression since they're only rated for 200 RMS a piece.
I want my trunk back and i want better bass. :)
wait, did Matt just say he wants his trunk back!?!?! :)
I thought you said sound was more important then storage, cmon now :)
Matt : did you ever find out what chip is in the stock GP radio? I'm still sorta curious if you ever get the time.
