Thread: amp
Results 1 to 19 of 19
  1. #1 amp
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    ok just put a kicker l7 4ohm with a kicker zx750.1 amp and when it hits the protection light blinks. i wired the + to + and - to - is that wired to to ohms or is it wrong?
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  2. #2 Re: amp
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    Probably not a good enough ground. If its not bridged, prolly a weak ground. ZX750 = needs a good ground!
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  3. #3 Re: amp
    Grayslake
    alright thanks ill have to try a better ground
  4. #4 Re: amp
    swift current,sask.
    Quote Originally Posted by JoelW98GTP View Post
    Agreed, if not check the voltage at the amp and make sure all of your battery connections are tight.
  5. #5 Re: amp
    Grayslake
    alright ill check all of this tomorrow
  6. #6 Re: amp
    Or the amps toast GOOD LUCK BUDDDDDDDDDDDDDYYYYYY
  7. #7 Re: amp
    Michigan
    If all checks out ok, and the amp is still clipping try beefing up the body ground at the battery by putting a 4 gauge cable between the negative post on the battery and the body of the car. this is very commonly overlooked
  8. #8 Re: amp
    Quote Originally Posted by ninjazx6e View Post
    Factory grounds such the big one.
    That doesnt mean make your own... Use factory positions but make sure they're sanded down to bare metal etc.
  9. #9 Re: amp
    Grayslake
    ok well i got a better ground but it still blinks on low notes and it doesn't seem as loud as it should be. any ideas as y?
  10. #10 Re: amp
    swift current,sask.
    Quote Originally Posted by grand2000prixgtp View Post
    Check and see what kind of voltage you are getting at the amp.
  11. #11 Re: amp
    swift current,sask.
    With that kind of power you need to upgrade the ground under the hood and the alternator power wire. Or commonly known as "the big 3".
  12. #12 Re: amp
    Grayslake
    what do i need to do to upgrade it?
  13. #13 Re: amp
    swift current,sask.
    I did the actual "big 3" so an alternator to fuse relay, battery ground and a motor to chassis ground. Sorry for the dirty mess, and no i didn't have a ring terminal on the motor to ground wire.
    amp Attached Images
  14. #14 Re: amp
    even if you used a section of the existing wire but routed it the shorter route it'd be much better than stock. Also free
  15. #15 Re: amp
    Grayslake
    and that helps alot?
  16. #16 Re: amp
    swift current,sask.
    Oh yes, big time! The stock wiring is 8 gauge if im not wrong. 8 gauge is good for about 60 amps so and your alternator puts out over 100. I had some serious dimming issues before and now i have little if none.
  17. #17 Re: amp
    Its the fact that the 8 gauge cable is 10 feet long.
    If the 8 gauge cable was say a foot and a half, this wouldn't be an issue with our cars.
  18. #18 Re: amp
    Grayslake
    alright ill have to do that then
  19. #19 Re: amp
    MO
    ahh, the big 3. way to go
    <brandonl2000> LMAO D!!
amp
