Thread: Upgrading my alternator
Results 21 to 40 of 43
  1. #21 Re: Upgrading my alternator
    Kansas
    I need more like 170 amps then 125
    SOLD 1999 GT Silvermist TS
  2. #22 Re: Upgrading my alternator
    I don't know what you need it for... But sure, find parts store, find alt shop and pay him some money and you're in buisness.
  3. #23 Re: Upgrading my alternator
    Feb 2009
    Virginia
    If your lights aren't dimming there's no reason for a higher output alternator. Do you do burps or anything SPL related? If not...don't get a new alternator. You won't see a difference in anything at all.
    I guarantee you that you're setup isn't sapping enough power on daily tunes to necessitate a new alternator. If you're having any problems at all find a buddy who has something better than a ryval and try that amp hooked up in your system. If you have light dimming issues it'll be resolved with a better amp.
    11 is louder than 10!
  4. #24 Re: Upgrading my alternator
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by I800C0LLECT View Post
    big 3 maybe? thats what i'm going for when I get home...
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  5. #25 Re: Upgrading my alternator
    Feb 2009
    Virginia
    Nope. Big 3 won't help amps or sound either. Either your alternator makes enough power or it doesn't. However, very few people reach the extents of their alternator with daily audio.
    When you "crank" it you have maybe 10 watts going to a single speaker. That's 40 watts for four speakers. Add a sub...maybe 60 watts total. Let's say the amps are 50% efficient. That means you're drawing 120watts. No reason for 0awg, big 3, alternator, etc.
    Most of what you see people installing is snake oil and advertising. However, this is assuming you've set up your system correctly too. Misalign your gain, create some square waves and all hell breaks loose.
  6. #26 Re: Upgrading my alternator
    Aug 2008
    Fayetteville, NC
    I dont understand why caps are trash then.
  7. #27 Re: Upgrading my alternator
    Feb 2009
    Virginia
    EDIT: My numbers may be off but the theory still applies, sorry :/
    This might help too:
    Grand Prixs Of North America • View topic - Capacitor Info
    Think of a capacitor as a battery that can maintain a very high voltage but doesn't hold a lot of power so it maintains the ability to discharge VERY quickly.
    A battery is charging ~12.6V. If you're charging system drops below 12.6V then your battery is no longer charging and you begin to draw current from the battery. A 1 farad capacitor only maintains enough juice for about 1/10 a second in a 1000watt system. Once the capacitor is drained it becomes a secondary load on the charging system. You're cap will not discharge until you drop below the charging state for the battery. However, it will wait until the battery returns to a charging state before becoming an additional load on the charging system.
    So in that instance, why use a capacitor?
    In addition, a well designed amplifier already has the capacitance necessary to maintain it's output built into it's power supply section.
    Although the voltage is low on this...here's a photo of a 1 farad capacitor...
    1 Farad 5.5 Volt BackUp Capacitor
    Feel like you were ripped off yet? I will admit, this one is only good for 5.5V. A higher voltage would increase the size but you could always wire four of them for 22V and 4F.
    Here's another...
    CPAG1.0F - 1.0F 2.5V Aerogel Super Capacitor Products Solarbotics
    So after it's all said and done, you either need a higher output alternator or a better amp
  8. #28 Re: Upgrading my alternator
    Aug 2008
    Fayetteville, NC
    ^^^ lol...good job man, bravo lol
  9. #29 Re: Upgrading my alternator
    New Jersey
    1800collect : I've often asked people why they use caps in cars. I've never met an electrical engineer that thought it made sense or would work.
    I ran a 600W a/d/s system for 7 years on a stock 105A delco alt. I never had a problem, But i was easily able to overload the alt even at 3000rpm. But it didn't matter, under 99% of conditions the alt had plenty time to catch up. Before a/d/s was bought by directed I often talked to the tech support guy, who also told me not to bother with caps.
    I had a run of 4AWG wire to a fusebox that split to two 8AWG runs, to the 2 amplifiers. I don't know if i necessarily needed as big as 4AWG, but the price was right at the time
    The way the price of copper has shot up since then, I might look into some 24AWG
  10. #30 Re: Upgrading my alternator
    You might still have voltage drop.
    If i'm at 14.4V at my alt, i'm at 14V at the fuse box and 13.5-7V at the distro block in the trunk with a single run of 4 gauge.
    Thats with the amps idling too.
  11. #31 Re: Upgrading my alternator
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
  12. #32 Re: Upgrading my alternator
    Yeah and he has customer service issues.
    But they all probably do.
    Hence my vote going out to a local shop.
  13. #33 Re: Upgrading my alternator
    Aug 2008
    Fayetteville, NC
    i just dont see it....I have a ZX1000 amp and my headlights blink, not bad but they do. my DIC usually says my car runs at 11.4V, depends, it floats up and down...
  14. #34 Re: Upgrading my alternator
    I dont know how your car starts in the morning...
    Get a HO alt STAT!
  15. #35 Re: Upgrading my alternator
    New Jersey
    eh, keep something else in mind. 1000W output will only produce 3db louder then 500W. and will easily consume 2000W instead of 1000.
    my system with the 480W for subs and 160W for components was able to hit 118DB in my truck. I typically tried to keep it down around 90db on long trips, I do like my hearing. But there were times id almost clip the system playing a good house song.
  16. #36 Re: Upgrading my alternator
    Quote Originally Posted by MrTube View Post
    This
  17. #37 Re: Upgrading my alternator
    Feb 2009
    Virginia
    This is a great thread great input everybody. Enough info to steer people in the right direction.
  18. #38 Re: Upgrading my alternator
    Factor in thermal compression and that kind power means NOTHING unless you've got very good drivers.
  19. #39 Re: Upgrading my alternator
    Aug 2008
    Fayetteville, NC
    Get a HO alt STAT!
    new yellow top battery maybe? when system is off or down it runs 14-15V, I dunno been sooooo long since I was home, Lmao...2 days and I begin my travel back to the states...
    then i'mmma get me a WS6 bizzznitches...
  20. #40 Re: Upgrading my alternator
    Ha fair enough.
    Go LSx
  1. upgrading performance
    By ndwings11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2009, 03:11 PM
  2. Need Help Upgrading '04 Grand Prix GTP
    By hinkaj02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2009, 07:57 PM
  3. advice on upgrading a stock '98 gt
    By mhoran89 in forum Introductions/Noob Questions
    Last Post: 06-05-2009, 04:56 PM
  4. Upgrading to 3.29 Gears
    By scottmmckinney in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-05-2009, 10:14 PM
  5. Fan Upgrading...
    By JoshMcMadMac in forum General Tech Discussion
    Last Post: 08-16-2008, 08:42 AM
