Thread: Upgrading my alternator
Page 3 of 3 FirstFirst 123
Results 41 to 43 of 43
  1. #1 Re: Upgrading my alternator
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    Ha fair enough.
    Go LSx
    i'll be contacting u or 1800 on some more audio tweaking, I want to up my amp to a zx1500. I know my lights are gonna blink and low voltage will begin. with a HO alt. would I then need to do the big 3 to support the new Alt?
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  2. #2 Re: Upgrading my alternator
    Probably to the last part there.
  3. #3 Re: Upgrading my alternator
    Feb 2009
    Virginia
    As far as I know you don't need to necessarily upgrade the big "3". Just throw a bigger gauge to the battery(assuming your amp POS comes from the battery) and be sure that that the battery is grounded to the frame properly. Apparently our vehicles maintain a ground from the alternator to the block AND the frame.
    So by grounding the battery to the frame you don't have to upgrade the ground from the alternator that leads to the block and frame.
    That seems confusing...so here's the link:
    Grand Prixs Of North America • View topic - cant find The Big 3
    Factory the engine has a ground for the battery to the frame and engine block to the frame, the ground locations are different but you can change them as long as the battery and engine block are grounded.
    Example:
    Engine block ground - to - battery ground - to - frame
    Engine block ground - to - frame :: battery ground - to - frame
    Either one will work but depending how you do the wire and length you could obtain more resistance then what you currently have and cause issues but if the grounds stay under 18 inchs you will normally avoid resistance issues. Now if the engine block wire does have to be longer then 18 inchs that is fine ASLONG as the battery ground is less then 18 inchs.
    If you guys would like some pictures of the big 3 I have a few when I was doing the rewire.
    11 is louder than 10!
  1. upgrading performance
    By ndwings11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2009, 03:11 PM
  2. Need Help Upgrading '04 Grand Prix GTP
    By hinkaj02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2009, 07:57 PM
  3. advice on upgrading a stock '98 gt
    By mhoran89 in forum Introductions/Noob Questions
    Last Post: 06-05-2009, 04:56 PM
  4. Upgrading to 3.29 Gears
    By scottmmckinney in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-05-2009, 10:14 PM
  5. Fan Upgrading...
    By JoshMcMadMac in forum General Tech Discussion
    Last Post: 08-16-2008, 08:42 AM
