Thread: tuning a sub and stereo
Results 1 to 13 of 13
  1. #1 Re: tuning a sub and stereo
    Feb 2009
    Virginia
    Quote Originally Posted by Toofastgs View Post
    WOW so much fail.
    EDIT:
    In an effort to appease others...
    Low Pass Filter: A filter which attenuates frequencies which are above it's stated "cut off" frequency.
    Examples using a system:
    Woofer
    HPF -- 25hz @ 24db (incorrectly referred to as subsonic filter, also known as infrasonic filter)
    LPF -- 125hz @ 12db
    Mids
    HPF -- 100hz @ 12db
    LPF -- 2.4khz @ 12db<------denotes fall off/attenuation
    Tweet
    HPF -- 2.6khz @ 12db
    In the example above, I use the LPF to let my sub play 20hz to 125hz. I have the option of using an Infrasonic filter but I don't...I threw that in as part of the example so you'd understand it's purpose. At the other end of the spectrum my tweeter plays from 20khz to 2.6khz.
    Typically when you use an HPF and LPF on the same driver it's referred to as a band pass. Not to be confused with bandpass enclosures. Same idea though since most bandpass enclosures require an infrasonic filter.
    Matt will correct me if I made any mistakes
    11 is louder than 10!
  2. #2 Re: tuning a sub and stereo
    SE Level Member hondo's Avatar
    Salt Lake City, Utah
    okay thanks for that, where is the best place in the trunk to get the best bass out of it? where should i aim it?
  1. Stereo
    By libretsel in forum Audio, Security & Visual Electronics
    Last Post: 08-21-2009, 06:41 PM
  2. Need help replacing my stereo
    By Draco in forum Audio, Security & Visual Electronics
    Last Post: 08-14-2009, 07:58 PM
  3. stock stereo
    By 59chevy in forum Audio, Security & Visual Electronics
    Last Post: 02-09-2008, 12:01 PM
