Found this for a 2004:
12volts red (50A), red (40A) + back of fuse box, passenger dash
Starter yellow + ign harn or BCM, conn. C1, pin 21
Notes: The BCM (Body Control Module) is below the driver side dash to the left of the steering column.
Second Starter N/A
Ignition pink + ign harn or BCM, conn. C1, pin 22
There are two pink wires in the BCM plug that meter as ignition. To verify that the correct wire is being energized for remote start, slide the key in the ignition key cylinder and then activate remote start. If the key in ignition warning chime comes on, then the correct wire is being energized.
Second Ignition N/A
Third Ignition N/A
Accessory brown + ign harn or BCM, conn. C1, pin 23
Second Accessory N/A
Keysense lt. green - ign harn or BCM, conn. C1, pin 40
If the service security lights comes on during remote start or after key takeover, see DirectFax document 1502.
Power Lock red/black - BCM, conn. C2, pin 2
Power Unlock orange/black - BCM, conn. C2, pin 11
Lock Motor gray 5wi BCM, conn. C2, pin 52
Unlock Motor tan 5wi BCM, conn. C2, pin 46
Parking Lights+ brown + front of fuse box, passenger dash
Parking Lights- brown/white - BCM, 18 pin plug, pin 8
Hazards tan - BCM, 18 pin plug, pin 16
Turn Signal(L) use hazards wire
Turn Signal(R) use hazards wire
Reverse Light lt. green + BCM, conn. C2, pin 42
Door Trigger see notes - BCM, conn. C2
Notes: The driver door trigger is gray/black in pin 26, the front passenger door is black/white in pin 17, the left rear door is lt. blue/black in pin 7, and the right rear door is lt. green/black in pin 5. Use all four wires and diode isolate each.
Dome Supervision gray/black + BCM, conn. C1, pin 43
Trunk/Hatch Pin red/black - BCM, conn. C2, pin 3
Hood Pin N/A
Trunk/Hatch Release lt. blue + BCM, conn. C2, pin 45
Power Sliding Door N/A
Factory Alarm Arm lt. green - BCM, conn. C2, pin 22
Factory Alarm Disarm purple - BCM, conn. C2, pin 24
Disarm No Unlock see factory alarm disarm
Tachometer white ac ignition control module, pin E
Notes: The ignition control module is on top of the engine towards the passenger side.
Wait to start N/A
Brake Wire white + BCM, conn. C2, pin 30
Parking Brake orange/black - BCM, conn. C2, pin 9
Horn Trigger black - BCM, conn. C1, pin 4
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
PASS-Key III
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Radio 12v orange + radio harness
Radio Ground black/white - radio harness
Radio Ignition (Class 2 Serial Data)
Radio Illumination gray (dimmer) + radio harness
Factory Amp Turn-on same as power antenna wire
Power Antenna purple + radio harness
LF Speaker +/- tan - gray +,- radio harness or amplifier
Notes: The amplifier is under the rear deck.
RF Speaker +/- lt. green - dk. green +,- radio harness or amplifier
LR Speaker +/- brown - yellow +,- radio harness or amplifier
RR Speaker +/- dk. blue - lt. blue +,- radio harness or amplifier
Dont know if it will help me yet but will post all that I find just incase it helps others.
