Thread: AC Delco plugs
Results 1 to 4 of 4
  1. #1 AC Delco plugs
    Nov 2008
    South Dakota
    Before i bought my car the shop at the dealership put new plugs in it and they put replacement AC delco's in that are double platinum??..are those good enough for future mods or should i go with TR55's or 104's? Thanks for the help
  2. #2 Re: AC Delco plugs
    TDCRacing
    Guest
    Well generally speaking it would be better to switch to a copper plug. As far as wich plug to switch to in the future it would depend on exactyl what mods you plan on doing.
  3. #3 Re: AC Delco plugs
    Oklahoma
    I'll back up TDC's recommendation. Go with the copper plugs, but which ones you use is very much dependent on your mods and such. If you want to stay with stock copper plugs the Autolite 606's will be what you need.
  4. #4 Re: AC Delco plugs
    Nov 2008
    Searcy,Arkansas
    Not sure if you guys know this but AC DELCO makes NGK plugs. Mine stock are with NGK and it says "Acdelco" on the top. And the ones in mine are the copper NGK. They came stock.
    EDIT: Not sure is they make make them. But I know the co-make or whatever! lol
  1. plugs?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2008, 12:32 PM
  2. TRI-55X Plugs=bad KR for my car?
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2008, 04:44 PM
  3. Delco Cruisers Mega Car Show
    By Injun #4 in forum Shows and Events
    Last Post: 07-11-2008, 10:55 PM
  4. Pntiac delco???
    By TMOTA503 in forum Audio, Security & Visual Electronics
    Last Post: 03-04-2008, 09:49 AM
