Thread: High/Low beam simultaneously
Results 1 to 5 of 5
hacket High/Low beam simultaneously 11-15-2009, 12:59 AM
RedDawnGXP Re: High/Low beam... 11-15-2009, 01:16 AM
Vinn Re: High/Low beam... 01-22-2010, 07:02 PM
Spartan GL Re: High/Low beam... 01-23-2010, 03:02 AM
kjohnson Re: High/Low beam... 01-23-2010, 10:37 AM
  1. #1 Re: High/Low beam simultaneously
    Ohio
    I am interested in doing this as well. There are many threads showing how to do this with HIDs, but I am keeping my projectors halogen. I installed Osram Nightbreaker H1 bulbs in the projectors which improved the output a little. If I could have both the 9005 bulb and the projectors on, I think the high beam output would be great.
  2. #2 Re: High/Low beam simultaneously
    Largo, Florida, United States
    very interesting idea.
  3. #3 Re: High/Low beam simultaneously
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    There are tons and tons of different ways that you could do this.
    the easiest way that I can think of if you didnt want them to blink is to find a switched power source( turns on with the ignition like your cd player) take that wire and attach it to a relay. that would get rid of power loss since the power isnt traveling as far and would make it so they wouldnt blink. then just have your highbeams set up like normal so when you flip them on your light turns on on your dash.
    let me know if you want me to draw a quick diagram
    but like I said there are tons of different ways to do this. just make sure that when you do it take your time and get all of your connections good and tight as well as water proof so they do not fail.
    edit i for got you can also put in a toggle in line with the power from the 12 swich and you could then just run with just your fog lights on if you wanted to
    silver 2003 Grand Prix GT List is on it's way to be updated
  1. fog lamps while high beam?
    By chris189 in forum General Tech Discussion
    Last Post: 09-29-2009, 02:35 PM
  2. New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    By GeddyLee in forum General Tech Discussion
    Last Post: 01-29-2009, 07:26 PM
  3. Hid with a high beam
    By crywolf in forum Visual/Body Modifications
    Last Post: 01-27-2009, 07:13 PM
  4. 04+ DRL and High/Low beam wiring
    By ponyfool in forum Visual/Body Modifications
    Last Post: 12-01-2008, 02:31 PM
  5. HID high beam question.
    By Nabster in forum Visual/Body Modifications
    Last Post: 04-15-2008, 05:26 AM
