Thread: fog lamps while high beam?
Results 1 to 6 of 6
  1. #1 fog lamps while high beam?
    Walkerton
    Does anyone know how to make the fog lamps STAY on when I flip to the highbeam lights? Why do they go out? Is more light not better for safety? What was Pontiac thinking? Maybe they could just put some real headlights in from new?
    Anyway, if anyone knows how to do this mod without running a a complete new wire then I would appreciate it. Car is a 2002 GT. Thanks
  2. #2 Re: fog lamps while high beam?
    GTP Level Member SuperSport's Avatar
    Michigan
    Because Pontiac thinks that 23 watt fog light bulbs are going to blind people.
    Heres the write up.
    http://www.grandprixforums.net/f73/f...eams-7318.html
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: fog lamps while high beam?
    Feb 2008
    Hmm... Mine just does that on its own... F'd up relay, maybe?
  4. #4 Re: fog lamps while high beam?
    Wausau, WI
    Quote Originally Posted by DanGTP View Post
    or previous owner already did this mod....
  5. #5 Re: fog lamps while high beam?
    Feb 2008
    Quote Originally Posted by Liquifire View Post
    I AM the PO...lol I've had the car since it was new. They used to stay on for just a second after hitting the high's, then it got to where they don't go out at all. I wonder if it is the relay not switching, or if I have a wiring gremlin. I kind of don't want to fix it, though, because I like having my fogs on with my high beams.
  6. #6 Re: fog lamps while high beam?
    Barksdale AFB, LA
    Quote Originally Posted by chris189 View Post
    That they should comply with DOT regulations. No car is allowed to have its fogs on with the brights. Federal law.
    2009 Subaru Impreza WRX STI
  1. High Beam Indicator light stays on
    By mike4567 in forum General Tech Discussion
    Last Post: 08-07-2009, 08:05 PM
  2. New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    By GeddyLee in forum General Tech Discussion
    Last Post: 01-29-2009, 07:26 PM
  3. Hid with a high beam
    By crywolf in forum Visual/Body Modifications
    Last Post: 01-27-2009, 07:13 PM
  4. 04+ DRL and High/Low beam wiring
    By ponyfool in forum Visual/Body Modifications
    Last Post: 12-01-2008, 02:31 PM
  5. HID high beam question.
    By Nabster in forum Visual/Body Modifications
    Last Post: 04-15-2008, 05:26 AM
