Thread: Radio Reception and Window Tint.
Results 1 to 20 of 25
  1. #1 Radio Reception and Window Tint.
    GTP Level Member SuperSport's Avatar
    Michigan
    Maybe its just my imagination but it seems ever since I got my windows tinted, my radio reception isnt as good. I can still hear it just fine, but it seems to be slightly weaker than it was before. I know the antenna is in the back glass and they tinted over it, so does tint affect anyone elses radio reception?
    Im not blaming the tint, Im blaming the idiot who decided to put the antenna in the back glass...
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  2. #2 Re: Radio Reception and Window Tint.
  3. #3 Re: Radio Reception and Window Tint.
    Wooster, Ohio
    your either going crazy, driving different routes, or your head units tuner is taking a dump. I could never imagine tint to effect reception
  4. #4 Re: Radio Reception and Window Tint.
    Kansas
    Pretty sure tint cant have that effect
    SOLD 1999 GT Silvermist TS
  5. #5 Re: Radio Reception and Window Tint.
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    window tint does have an effect on AM radio reception, but not on our cars. Some new cars have some crazy special antenna that requires a slightly more expensive tint film in order to not affect the reception. either that or my tint guy is a scam artist, but i'm pretty sure he's not since he only put the expensive tint on my mom's BMW.
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  6. #6 Re: Radio Reception and Window Tint.
    Michigan
    Then its my imagination. Thanks.
  7. #7 Re: Radio Reception and Window Tint.
    Nov 2009
    A place called Hope.
    I had this discussion with my tintmeister, and used ceramic stuff to ensure radar detector, cb, etc. would not be affected.
    On another odd note, after putting new tires (Dunlop SP60s, replacing ContiExtremeContacts) on wife's car (outside mast antenna), radio interference declined considerably.
  8. #8 Re: Radio Reception and Window Tint.
    canada
    never heard of tint affecting that but I do notice on my car the reception is not as strong as my previous car. I have not tint, is there anything I should check for reception. I pull my head unit the other day and all looked good, I was only checking for connections tho.
  9. #9 Re: Radio Reception and Window Tint.
    Mishawaka
    I wouldnt think the tint would affect the reception since the tint is installed on the interior of the car's rear window.
  10. #10 Re: Radio Reception and Window Tint.
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    actually the antenna on the back glass was a decent idea to me. since not having an antenna on the hood is awesome!
    when I was a kid, it snowed and my moms new grand am's antenna had iced up. So I pulled it back alittle to watch it wiggle and fling.... needless to say, it only snapped in two!
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  11. #11 Re: Radio Reception and Window Tint.
    Wooster, Ohio
    update! I just found out tint can have an effect, not because of the tint itself but if your tinter trimmed the tint on the inside of the window he could of cut the antenna, making it obviously not work right. I knew you could do this with the defroster but guess i didn't think about the antenna being basically the same. Something to keep in mind
  12. #12 Re: Radio Reception and Window Tint.
    Michigan
    Quote Originally Posted by Pittman06 View Post
    Well the tint on my rear window still looks like crap, bubbles and hair everywhere in it. I wouldnt be surprised if he knicked a little bit of the antenna....
  13. #13 Re: Radio Reception and Window Tint.
    Wooster, Ohio
    from what i was told all it takes it a knick to basically deem it worthless
  14. #14 Re: Radio Reception and Window Tint.
    Spray on tint? May cost >9000 more but it sure a **** won't peel and bubble.
    Also, other than news, (traffic and weather as well) what is there to listen to on the radio?
  15. #15 Re: Radio Reception and Window Tint.
    Michigan
    In America, they play music on the radio.
  16. #16 Re: Radio Reception and Window Tint.
    In Canada, they play ****ty music on the radio.
  17. #17 Re: Radio Reception and Window Tint.
    CT
    Ive seen tint affect radio reception. Also if you turn the rear defroster on and your reception goes down you need a new rear window.
  18. #18 Re: Radio Reception and Window Tint.
    GT Level Member Joe m's Avatar
    mesa,az
    lol.. damn canadians and there crappy music!
  19. #19 Re: Radio Reception and Window Tint.
    Quote Originally Posted by Joe m View Post
    Where do you think we got this crappy music? Does the states come to mind?
  20. #20 Re: Radio Reception and Window Tint.
    not anything worth listening to unless you enjoy country, crappy pop rock, and rap that gives the old school rappers a bad name.
  1. radio reception
    By echarleswhyte in forum Audio, Security & Visual Electronics
    Last Post: 10-12-2010, 08:48 PM
  2. Window Tint
    By 04gpking85 in forum Visual/Body Modifications
    Last Post: 08-19-2009, 09:08 AM
  3. What to Do About My Window Tint
    By Lsick7 in forum Visual/Body Modifications
    Last Post: 07-12-2009, 11:08 PM
  4. aftermarket head unit radio reception problem
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 06-22-2009, 10:55 PM
  5. Bad Radio Reception
    By hester21289 in forum Audio, Security & Visual Electronics
    Last Post: 02-18-2008, 07:56 PM
