Dont cut up the factory harness. Buy the adapter harness from zzp or who ever you want. If you have bose then you have to run a jumper wire from your remote turn on to the pink wire on the bose plug that would no longer be used.
If you can follow directions I think you could do it. Butt connectors and crimping would be fine for inside the car.
Second time in the past two days I've ****ed up on terminology. I meant the adapter harness.
