The most difficult part might be attaching the head unit's harness to the vehicle's wire harness. You can crimp or solder, either will work, but aside from removing the dashboard, thats about it. The things you've mentioned are really easy.
Dont cut up the factory harness. Buy the adapter harness from zzp or who ever you want. If you have bose then you have to run a jumper wire from your remote turn on to the pink wire on the bose plug that would no longer be used.
If you can follow directions I think you could do it. Butt connectors and crimping would be fine for inside the car.
