When you open the door on the side of the dash there is a little plastic insert you can pop out. Try putting it in there.
3/4" seems to be the more accurate size. If you're asking that to see if you can fit the original spot, that entirely depends upon the bezel of the tweeter you're replacing it with.
That third idea doesnt seem like it would pan out well... Do you have an aftermarket amp? If not, then hook the stock wiring to the speakers so that your aftermarket HU will power them. If you DO have an aftermarket amp and you want both to be hooked up you will have to disconnect the wiring in the harness else it will be plugged into the HU regardless.
Yea I have an aftermarket amp i'm going to use. I want to hook the stock wiring up at the speakers but keep it UNHOOKED at the HU, then if I need to put the stock HU back in I can just disconnect the aftermarket amp and plug the HU in and have sound without taking the door panel off and hooking the stock wiring backup. (no factory amp btw)
