Thread: If I put a new stereo in would I still be able to use the stock tweeters>?
Results 1 to 13 of 13
  1. #1 If I put a new stereo in would I still be able to use the stock tweeters>?
    Rhode Island
    thats it
  2. #2 Re: If I put a new stereo in would I still be able to use the stock tweeters>?
    GTP Level Member SuperSport's Avatar
    Michigan
    Yes because the tweeter connection is at the speaker. So as long as the left and right speaker is wired to the head unit, the tweeters should work.
    Correct me if im wrong.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: If I put a new stereo in would I still be able to use the stock tweeters>?
    Ohio
    ^ ur right. changing the headunit wil have no affect on the functionality of the speakers as long as u hook it up right.
    00 GTP demodded and forsale
  4. #4 Re: If I put a new stereo in would I still be able to use the stock tweeters>?
    As long as you don't have an external amp in your stock system. Do you have a Bose system? Also what year is it?
  5. #5 Re: If I put a new stereo in would I still be able to use the stock tweeters>?
    Charles City, IA
    They will still work with the bose. Run the remote turn on to the pink wire IIRC on the bose harness. Don't buy the $120 harness.
    SMGPFC Two Nipple General
  6. #6 Re: If I put a new stereo in would I still be able to use the stock tweeters>?
    How would you send a signal to the bose amp? Does it accept speaker level?
  7. #7 Re: If I put a new stereo in would I still be able to use the stock tweeters>?
    Charles City, IA
    Not sure how it works. I just know it does. Thats how I wired mine.
  8. #8 Re: If I put a new stereo in would I still be able to use the stock tweeters>?
    Rhode Island
    2002 with stock system-no bose
  9. #9 Re: If I put a new stereo in would I still be able to use the stock tweeters>?
    Quote Originally Posted by salannelson View Post
    Then its ALL GOOD.
  10. #10 Re: If I put a new stereo in would I still be able to use the stock tweeters>?
    Rhode Island
    Then its ALL GOOD.
    awesome, what if i were to put in new speakers as well?
  11. #11 Re: If I put a new stereo in would I still be able to use the stock tweeters>?
    GT Level Member gpgt04's Avatar
    MA
    well the tweeters would still work if you put in two way speakers or just replace the stock tweeters with the after market components. i did the latter
  12. #12 Re: If I put a new stereo in would I still be able to use the stock tweeters>?
    Ohio
    ^ the 2nd is what i did too
  13. #13 Re: If I put a new stereo in would I still be able to use the stock tweeters>?
    You'd have to cut the wire in order to get it to attach because the OE's have their own special connectors on them.
    Also, you might wanna just get a decent pair of component speakers. They'd sound better. If not, and you dont wanna crank it too much, wire it the way it was stock. If you wanna crank it, wire the tweeter and the new mid in series.
  1. NO CLUE: Adding AUX plug in for Ipod in stock bose stereo 2000 gp
    By sirpig34 in forum Audio, Security & Visual Electronics
    Last Post: 09-10-2009, 08:55 AM
  2. stock stereo louser
    By jillandjesses02 in forum Audio, Security & Visual Electronics
    Last Post: 05-09-2009, 06:52 AM
  3. stock stereo switch?
    By pski920 in forum Audio, Security & Visual Electronics
    Last Post: 12-17-2008, 11:20 AM
  4. Stock stereo backlight inop? Which speakers to replace stock?
    By Z28 in forum Audio, Security & Visual Electronics
    Last Post: 12-04-2008, 11:47 PM
  5. stock stereo
    By 59chevy in forum Audio, Security & Visual Electronics
    Last Post: 02-09-2008, 12:01 PM
