Thread: radio display problem
Results 1 to 11 of 11
  1. #1 radio display problem
    SE Level Member rambo33's Avatar
    Illinois
    i have a problem with my stock stereo. it works perfect but i can ot read the time or radio station on it. i have to use the heads up display to know what station im on. does anyone know how to fix this?
    Pontiac windshield banner decal, Grand Prix Mud Flaps, Grand Prix caliper overlay, trunk debadged, clear corners, sd air dam, fig polished grilles, rear bumper pontiac inlay....much more to come
  2. #2 Re: radio display problem
    Jul 2008
    sumter,south carolina
    get a new radio
    02 GTP with mods 05 GP for DD
  3. #3 Re: radio display problem
    Illinois
    lol im gunna but not right now so i wanted to get it fixed for now
  4. #4 Re: radio display problem
    Rhode Island
    i had this same problem. this sounds kinda funny and cheap, but flick the display with your finger a few times and it should come on.
  5. #5 Re: radio display problem
    Donating Users blkgp2000's Avatar
    Nov 2008
    IL
    The display is probably just burning out. This happened to mine and i sent it in to get it fixed and i'm pretty sure they said the display burnt out.
  6. #6 Re: radio display problem
    morris
    Quote Originally Posted by rambo33 View Post
    By removing the front dash cover you will gain access to radio.The small display window removes and there is a small bulb in there that you can replace.Radio is fine.The bulb is all it needs.
  7. #7 Re: radio display problem
    Iowa
    I just finished fixing my radio display. And have 3 others to fix. Yes there is a bulb in there but finding one became a real problem. I went to all the dealers and auto parts stores in the area and no one had one. I found one on ebay for $20.00. Then I found a website with the GM part number for $9.00. The part number is 16208443. Your dealer can order it and have it the next day. The next problem was removing the dash. I found that on another website and is fairly easy. Remove the plastic on the bottom by pulling straight down on the back. There are two plastic pins sticking up and can be felt by reaching on top. Then pull it towards you. Next remove two screws, one on each side. That will remove the panel under the steering colum. Then start removing the dash face by pulling the lower left corner towards you. It is held by metal clips. Work your way around until the foglamp switch. Unplug it and continue all the way aruond to the radio. Tilt the steering wheel down and remove it. The stereo is held in by 2 screws. Remove them and pull it out. Unhook the antenna, and the harness. There is a lock on the harness so be careful not to pull on the wires. When you get the stereo out take it somewhere so you have good light and plenty of room. You do not have to take any screws out just pop off the front. BE CAREFUL FOR STATIC ELECTRICITY!!!! Be sure you are discharged by touching something other than the radio. Wear a t-shirt and if possible no shoes or socks. One shock could kill your stereo because you will be working on the circuitboard. When you get the face off look at the cups where the bulb sits, mine was dusty and the bulb was good but I broke it trying to get it out because I did not know how to do it. The bulb is a quarter turn like a headlight. Turn it clockwise. Use a small pliers on the sides and be very gentle. Do not stick anything in the slot in the center or you will break the bulb. Inspect the cups and clean them if necessary. When you replace it put a small amount of electrical grease in the cups and on the bottom of the bulb. It should go in by hand. I hope this is useful. It is easy and requires few tools. I have searched this for a long time and read numerous solutions wich were wrong. The display is not LED. And you must remove the dash face to remove the radio.
  8. #8 Re: radio display problem
    Iowa
    To tell if it is the bulb or the circuit board turn on the radio, shine a flashlight on the display, if you can read it the bulb is burned out if you cant it is the board.
  9. #9 Re: radio display problem
    Mansfield Ct
    Can You tell me if that will illuminate the DIC unit as well? Both my radio and DIC display went out at the same time. I checked both with a flashlight and they are working fine, but you cant see the display of either. My Mechanic says to replace the units..
  10. #10 Re: radio display problem
    Iowa
    Im not familiar with the DIC. I haven't had one apart, but Im almost positive they are two completely seperate units. Its probably a freak thing they went out at the same time. Im sure there are seperate bulbs for each indicator in there. What they are I dont know .
  11. #11 Re: radio display problem
    Iowa
    One problem I came across when fixing these radios is usually what happens is the bulb does not make good contact with the circuitboard because of dust getting getting between the bulb ears and the cups. The cups get hot and melts the solder on the board. Im trying to find a replacement board on line but havent been able to find one. I am going to try to get one from AC Delco but they dont like to sell parts unless you are a qualified dealer. I dont know why because its my radio. And Im going to take it to an electronics store to see if they can fix it.
  1. Light bulb in radio display question
    By singularity in forum General Tech Discussion
    Last Post: 08-31-2009, 09:30 AM
  2. aftermarket head unit radio reception problem
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 06-22-2009, 10:55 PM
  3. Heads Up display, after Market Radio & Mp3s??
    By Talon in forum Audio, Security & Visual Electronics
    Last Post: 06-21-2009, 01:20 PM
  4. Radio Display Not Working
    By y1a3o in forum Audio, Security & Visual Electronics
    Last Post: 03-31-2009, 11:02 AM
  5. Center Display Help
    By Forrest in forum General Tech Discussion
    Last Post: 03-06-2009, 09:58 AM
