Thread: car sub/amp
Results 1 to 20 of 31
grand2000prixgtp car sub/amp 07-27-2009, 09:23 PM
Lawngoose Re: car sub/amp 07-27-2009, 09:24 PM
grand2000prixgtp Re: car sub/amp 07-27-2009, 09:29 PM
LOUDANDPROUDGTP Re: car sub/amp 07-27-2009, 10:06 PM
CMURDAx Re: car sub/amp 07-27-2009, 10:54 PM
grand2000prixgtp Re: car sub/amp 07-27-2009, 11:02 PM
Gregorius Re: car sub/amp 07-27-2009, 11:28 PM
grand2000prixgtp Re: car sub/amp 07-27-2009, 11:50 PM
Gregorius Re: car sub/amp 07-28-2009, 01:11 PM
grand2000prixgtp Re: car sub/amp 07-28-2009, 05:07 PM
Lawngoose Re: car sub/amp 07-28-2009, 12:33 AM
grand2000prixgtp Re: car sub/amp 07-28-2009, 07:28 AM
offroadfury6 Re: car sub/amp 07-28-2009, 08:50 PM
grand2000prixgtp Re: car sub/amp 07-28-2009, 11:03 PM
offroadfury6 Re: car sub/amp 07-28-2009, 11:39 PM
ohioGTP Re: car sub/amp 07-28-2009, 11:54 PM
grand2000prixgtp Re: car sub/amp 07-29-2009, 08:09 AM
Gregorius Re: car sub/amp 07-29-2009, 12:14 PM
grand2000prixgtp Re: car sub/amp 07-29-2009, 06:41 PM
Gregorius Re: car sub/amp 07-31-2009, 02:55 PM
Hawkins97 Re: car sub/amp 08-02-2009, 03:48 PM
I800C0LLECT Re: car sub/amp 08-01-2009, 12:40 AM
I800C0LLECT Re: car sub/amp 08-02-2009, 12:10 AM
Gregorius Re: car sub/amp 08-02-2009, 09:01 AM
I800C0LLECT Re: car sub/amp 08-02-2009, 10:15 AM
I800C0LLECT Re: car sub/amp 08-02-2009, 10:18 AM
I800C0LLECT Re: car sub/amp 08-02-2009, 05:14 PM
eddie97gt Re: car sub/amp 08-21-2009, 12:06 AM
I800C0LLECT Re: car sub/amp 08-28-2009, 07:27 PM
  1. #1 car sub/amp
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    so i just put a new amp in today i blew my old one and at low volume the sub/amp works really good but once i turn the volume up the sub/amp turn off. any idea as what it could be.
    thanks in advance.
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  2. #2 Re: car sub/amp
    Outer Space
    Is it hot to the touch when this happens? Could be a thermal fault. Is it well ventilated? Also does it clip before it does this?
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: car sub/amp
    Grayslake
    yea it gets really hot.
  4. #4 Re: car sub/amp
    Houston, TX for now
    Is it a new amp? If it is an older amp that was been abused or used with low ventilation, the thermal fault could be worn to wear it doesn't take much to trip it. Also check your ohm load compared to what the amp is stable at?
    2000 GRAND PRIX GTP COUPE WITH THE NORMAL LIST MODS TO MAKE IT LOUDER, FASTER AND OF COURSE SEXIER!! 267 WHP @ 9000 FT ABOVE SEA LEVEL
  5. #5 Re: car sub/amp
    GT Level Member CMURDAx's Avatar
    Toledo, Ohio
    my amp used to do that. but if you turn ur setting down just a lil it should help. mine was up all the way. my amp couldnt handle what my sub could take.
  6. #6 Re: car sub/amp
    Grayslake
    it a new amp just got it today. i did turn it down but then i cant hear the sub.and a guy i work with told me about the amp cause he has the same sub as i do (i sold the sub to him) and the amp works fine with his.
  7. #7 Re: car sub/amp
    GT Level Member Gregorius's Avatar
    Davenport, IA
    If it gets hot that fast, and shuts down before it kills itself <in like 10-30 seconds> gotta be an ohmage problem with the sub. Maybe the amp isn't 1 or 2 ohm stable, when your other one was. Could be an intermittent VC short in the sub, which is what bombed your old amp, and might eat this one, too.
    What amp and what subs do you have? Ported or sealed boxes?
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  8. #8 Re: car sub/amp
    Grayslake
    Quote Originally Posted by Gregorius View Post
    its an alpine type R sealed box with a pioneer amp
  9. #9 Re: car sub/amp
    Davenport, IA
    Quote Originally Posted by grand2000prixgtp View Post
    Model Numbers would help a lot...
  10. #10 Re: car sub/amp
    Grayslake
    gm-5400t
  11. #11 Re: car sub/amp
    Outer Space
    turn the gain way down and retest.. make sure your wires are touching ..ie + touching -
    Are you using a bridged mode?
  12. #12 Re: car sub/amp
    Grayslake
    Quote Originally Posted by Lawngoose View Post
    yea im using the bridged mode i have only one sub
  13. #13 Re: car sub/amp
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    2 channel pioneer amp? is the ( + ) hooked up on the 1st channel and the ( - ) on the 2nd channel? yeah defently if it gets hot that fast, somethings not right. any smoke or funny smell??
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  14. #14 Re: car sub/amp
    Grayslake
    Quote Originally Posted by offroadfury6 View Post
    yea thats how i have it hooked up. no smoke i havent looked at it for that yet and no funny smells. i had an old amp that i blew and it smelled and smoked like crazy this one is not like that yet. maybe ill return it and try a different one.
  15. #15 Re: car sub/amp
    Aug 2008
    Fayetteville, NC
    its either too much gain and the speakers are just sucking the life out of the amp or the impediance ( ur ohms, or also the way its wired up )
  16. #16 Re: car sub/amp
    ohio
    Yeah, Im thinking the gain is too high or the ohms are too low, try turning the bass boost down if you havent already also.
    Also try hooking it up not in bridged mode just to see if it still cuts off (it shouldnt cause you will only be using 1/2 the amp, but if it does, the amp most certainly has a problem!)
  17. #17 Re: car sub/amp
    Grayslake
    ok. i have turned the bass but ill try hooking it up in a different way.
  18. #18 Re: car sub/amp
    Davenport, IA
    GM-5400T
    Output Power (4 Ohm, <=1% THD) 125 Watts x 2
    Output Power (4 Ohm Bridged, <=1% THD) 380 Watts x 1
    Output Power (2 Ohm, <=1% THD) 190 Watts x 2
    Nice lil amp, but it is NOT 2 ohm stable in bridged mode. Most Type-R subs are Dual VC, or are 2 ohm..
    Are you sure the amp is getting a 4 ohm load?
    The Model # of the Alpine would help too
  19. #19 Re: car sub/amp
    Grayslake
    GM-5400T
    im not sure the model number on the on the sub but its an older one.
    do you know how i should wire the sub up to have it work right then?
  20. #20 Re: car sub/amp
    Davenport, IA
    Yes. If possible....
    I missed this post of yours:
    " it a new amp just got it today. i did turn it down but then i cant hear the sub.and a guy i work with told me about the amp cause he has the same sub as i do (i sold the sub to him) and the amp works fine with his."
    If you are SURE the subs are exactly the same, and you bought the same model Pioneer as he did, something is broken.
    Hook up the sub to one side of the amp, run it hard for a few minutes, then try the other side. That will test the amp and the sub, and verify that nothing is broken, and that you have a 2 ohm SVC sub.
    Is there 2 sets of posts on the sub? red black and on the other side red black? If so it's Dual Voice Coil......
