Thread: car sub/amp
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #1 Re: car sub/amp
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    Quote Originally Posted by Gregorius View Post
    Yes. If possible....
    I missed this post of yours:
    " it a new amp just got it today. i did turn it down but then i cant hear the sub.and a guy i work with told me about the amp cause he has the same sub as i do (i sold the sub to him) and the amp works fine with his."
    If you are SURE the subs are exactly the same, and you bought the same model Pioneer as he did, something is broken.
    Hook up the sub to one side of the amp, run it hard for a few minutes, then try the other side. That will test the amp and the sub, and verify that nothing is broken, and that you have a 2 ohm SVC sub.
    Is there 2 sets of posts on the sub? red black and on the other side red black? If so it's Dual Voice Coil......
    ok the sub model is swr-1221d. it has 2 red post and 2 black.
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  2. #2 Re: car sub/amp
    SE Level Member Hawkins97's Avatar
    Wabash, IN
    I'm thinking that ur amp wire isn't a big enough gauge to take the consuption of the amp. And plus you could do what i've done.. run ur wire from ur battery back to a compasitor. Remember every 1000 watts is equal to 1 fared. Example 2500 watts = 2.5 fared. With this you will never have amp shutoff or dimming of interior or exterior lights.
  3. #3 Re: car sub/amp
    Feb 2009
    Virginia
    Forgive me...I havent' read anybody elses post.
    If your Alpine Subwoofer is Dual Voice Coil (DVC) then you MUST MAKE SURE IT'S RUN IN SERIES!!!!!
    Bridged amps these days can only take a 4ohm load when bridged. That's it..final..done. You're lucky your amp has a shut off. If you don't have a DVC Sub we'll have to speculate some more.
    Here's a diagram to help
    Subwoofer Wiring Diagrams, One 2 ohm Dual Voice Coil (DVC) Speaker
  4. #4 Re: car sub/amp
    Feb 2009
    Virginia
    Please refer to my post one above yours...it'll fix your problem.
  5. #5 Re: car sub/amp
    GT Level Member Gregorius's Avatar
    Davenport, IA
    Quote Originally Posted by I800C0LLECT View Post
    Nope. Love the illustrations, but they don't really cover his setup. He should use both sides of the 2 channel amp. I suppose he could series the coils to the amp in bridge mode and get the same results. However, channeling each coil seems more natural, bypasses a couple of circuits inside the amp for a cleaner sound, and lets the natural impedance of the VC's compensate any manufacturing variances inside the amp. Plus the wires going to the coils carry less current individually, which is a plus, if like most people your just using 10-12 ga. for the speakers.
    I forgot about the12volt com, haven't been there in ages.
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  6. #6 Re: car sub/amp
    Feb 2009
    Virginia
    I'll admit...I didn't expect RMS handling to be that low...but that's what setting gains properly are for
    Majority of sub freq's can handle up to 10-15% distortion before an individual readily notices. Channel separation and "clean" amps aren't as big of a deal. That's why SQ oriented installs don't focus on the subs as much.
  7. #7 Re: car sub/amp
    Feb 2009
    Virginia
    And now that I think about it...you don't want his DVC's in stereo? I think we should go over this approach again....
    Bridged to Series please :/
  8. #8 Re: car sub/amp
    Feb 2009
    Virginia
    16awg wire is all he needs...not sure what he's running? I probably missed it in his post.
    WIRE
    I'm of the opinion that caps don't help anything :/
    Grand Prixs Of North America • View topic - Capacitor Info
  9. #9 Re: car sub/amp
    SE Level Member eddie97gt's Avatar
    Feb 2009
    roanoke va
    well the type r are all dual voice coils but they made a dual 2 and dual 4 if its dual 2 you want to series the coils aka run a jumper from positive of one coil to the neg of another and run that to your amp ... or just take the amp back and buy a mono block and that should solve all your problems . The type r is a very good sub and try to buy the little alpine mrp-500 its only about 200 bucks and works great with the type r if its a dual 4 . but if its dual 2 ohm stick with the 2 channel you got
  10. #10 Re: car sub/amp
    Feb 2009
    Virginia
    OP...was this ever resolved?
    Quick summation...
    Equipment
    1)Dual Voice Coil Subwoofer
    2)Two channel Pioneer amp
    Fix
    Bridge the amp and run the coils in series.
    Reason
    The Pioneer amp is stable at 4ohm when bridged. The Voice coils MUST be run in tandem. Meaning they must receive the same signal or else you'll jack up your sub [refer here: http:]//electronics.howstuffworks.com/speaker5.htm
    Therefore, you must run the coils off the same channel. To get the most out of your Pioneer amp you would need to bridge the channels. BUT!!! You're Pioneer isn't stable below 4ohms when bridged. That's why you must run the voice coil in series. [refer here: Subwoofer Wiring Diagrams, One 2 ohm Dual Voice Coil (DVC) Speaker]
