Thread: 6x9 Install and Removal - 05 Grand Prix
Results 21 to 40 of 41
  1. #21 Re: 6x9 Install and Removal - 05 Grand Prix
    Canada
    lol ..... english is not my native language so i have some problem to figure how to do this ..... so if someone have picture i will appreciate ..... all this just for a junk on the speaker ( i think)
    Grand Prix GTP 97 & Grand Prix Base 05 (Summer Ride & Daily Ride)
  2. #22 Re: 6x9 Install and Removal - 05 Grand Prix
    London Ont, Canada
    no pictures unfortunatly...
    start at the begning, take the bottom seat out
    remove the bottom bolts holding the seatbelts
    remove the top bolts that you showed in YOUR picture.
    pull the seats
    lift the deck lid cover
    replace.
  3. #23 Re: 6x9 Install and Removal - 05 Grand Prix
    Canada
    pull the seats
    replace.
    i try to remove the bottom seat but the passenger side dont come out , the driver side pop up with no effort but the other side is stuck .... i see a little plastic handle to unlock the seat but it dosent do anything .... is stuck roght here!!!
  4. #24 Re: 6x9 Install and Removal - 05 Grand Prix
    London Ont, Canada
    yeah.. take at look at how the drivers side clip works, sometimes you need a screwdriver or something to press the switch over to have it come up..
    trust me when i say It WILL come out.. might just take a bit of wiggle
  5. #25 Re: 6x9 Install and Removal - 05 Grand Prix
    Canada
    i cant compare to driver side because it seem to have no plastic handle .... maybe the previous user remove it for any reason .... but i check in my 97 GTP ... does it the same plastic lock ?
  6. #26 Re: 6x9 Install and Removal - 05 Grand Prix
    London Ont, Canada
    mine was a small ring on plastic that i pulled.. it popped up and i took it out lol
  7. #27 Re: 6x9 Install and Removal - 05 Grand Prix
    Canada
    ok after some time i remove the seat ..... but now i have 5 bolts .... 2 for the seat belt and 3 on the black metal plate .... i remove the 2 bolt of seat belt, the bolt on the senter but the bolt at each side is ultra tight ... i cant unscrew it so .... im blocked another time
  8. #28 Re: 6x9 Install and Removal - 05 Grand Prix
    Canada
    .... some photos ....
  9. #29 Re: 6x9 Install and Removal - 05 Grand Prix
    London Ont, Canada
    that plate should be whats holding down the back., dont forget the uppers too...
  10. #30 Re: 6x9 Install and Removal - 05 Grand Prix
    SE Level Member aricshep's Avatar
    Cedar Falls, Iowa
    Good instructions Mad, I think I'll install my Alpines tommorrow in my '08 GP...should be the same instructions for my year...I hope
  11. #31 Re: 6x9 Install and Removal - 05 Grand Prix
    London Ont, Canada
    me too lol, ive got a 99'
    the prinicpals are the same
  12. #32 Re: 6x9 Install and Removal - 05 Grand Prix
    Cedar Falls, Iowa
    Ok I just tried to pull the clips out from underneath the seat cushion, to remove the lower backseat, and couldnt get it to budge. Looks like Lentrave got further than I did, I couldnt even get my seat cushion out. My Alpines are screaming to replace the stock speakers too lol. Im so frustrated.
  13. #33 Re: 6x9 Install and Removal - 05 Grand Prix
    London Ont, Canada
    its one of thoes things where its hard to explain how to do it, ya just gotta get in ther eand do it lol
  14. #34 Re: 6x9 Install and Removal - 05 Grand Prix
    Cedar Falls, Iowa
    When you pull the tabs and it releases do the seats just come off or do you have to pull back than up? I tried through a 6 pack of beer and still came up empty lol, Ill try again tommorrow w/my hang over lol.
  15. #35 Re: 6x9 Install and Removal - 05 Grand Prix
    London Ont, Canada
    under the front lip of the seat there are tabs, pop them, then lift up, grabbing the front of the seat, and lift, it will come up
  16. #36 Re: 6x9 Install and Removal - 05 Grand Prix
    Canada
    yeah .... lift .... what i do its i push the back of the seat down to unclip the seat from de black plate and i lift the back of the seat to acess the front clip ... and i take a screwdriver to push the clip because just with the tabs its not enought to release the seat.... its hard to explain .... and for those bolts realy hard to remove i use a electric impact and its work.... you can see the back clip on the black metal plate on this photo ... at the left (between the seat belt and the yelow flashlight)
  17. #37 Re: 6x9 Install and Removal - 05 Grand Prix
    London Ont, Canada
    did you get to your rear speakers yet?
  18. #38 Re: 6x9 Install and Removal - 05 Grand Prix
    Canada
    yes ... thanks for the help !
  19. #39 Re: 6x9 Install and Removal - 05 Grand Prix
    GT Level Member Gregorius's Avatar
    Davenport, IA
    Do all year GP's have 4 deck speakers like in the 98 GTP? I had 2 6x9's and some smaller 3x5's in the rear deck, stock. I'm thinking just swapping out the 6x9 might cause problems if the smaller drivers are left connected..
    Just thinking out loud.
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  20. #40 Re: 6x9 Install and Removal - 05 Grand Prix
    London Ont, Canada
    my 99 only had 2 rears.. you might have like a bose system or something
  1. '98 Grand Prix 3800 Oil Pan Removal Help
    By WoR in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-08-2009, 12:32 AM
  2. ==> H@lp Asap, TENSIONER Pulley Removal & Install <==
    By KevSorbo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2009, 08:26 PM
  3. ==> H@LP w/ TENSIONER Pulley Removal & Install Please <==
    By KevSorbo in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-30-2009, 08:14 PM
  4. 60 V6 Engine Water Pump Removal And Install [*]
    By 19SE92 in forum How To Write-Ups/Tech Tips
    Last Post: 03-09-2008, 09:15 AM
  5. How do I install front license plate on 2006 Gran Prix
    By DMC-12 in forum Off Topic Discussion
    Last Post: 02-16-2008, 11:43 PM
