Was wondering how you remove the stock 6x9s in an '05 Grand Prix. The only think that I can see is eaither removing the rear deck or pulling up the stock covers? Is there a trick to removing them or what? Some help would be greatly appreciated it!
By the way this is not the bose system.
ANYONE? Id like to put in my 3 waysHelp?
for my 98, i had to pull up the bottom of the back seat, undo the bolts holding the upper part of the back seat on and take it off, then pull up the rear deck
The same holds true for the 04+ GPs, you have to remove the bottom the rear seat cushion and then you have undo the two or three bolts that secure the top portion of the back seat to the underbody, where you removed the bottom backseat cushion. Once those the bolts are removed you can take off the top portion of the back seat and then lift off the cover over the speakers and then you will have your access.
And to reassemble, just do reserve of what I said above![]()
I hope that helps.
you remove the bottom back seat with some clips located under the front of the cusion. then take off some botls you see there, then life wiggle and pull, and your seat is off
god i remember when i started into my rears, i was so niave that i thought i could go trunk side.. lol ... took me like 20 mins to figure out how to get the rear seat off..
then i could get it out once unbolted, spent another 20 looking for morebolts, then i got angy and hit it a few times and sure enough they came out lol
so yeah, Wiggle FTW lol
yes im a noob but are sure this apply to 05 grand prix ? .... because i just have to pull down the seat (to the trunk) to have acess to some bolts?![]()
yeah, the bolts in question actually hold the seatbelts down, saftey and all...
i think i had 3 bolts?, yeah the only diff you will find is your seats can fold down, make sure they are secured first, then you can remove em easy
ok like this .... http://img80.imageshack.us/gal.php?g=1002566.jpg this is the passenger side
no i think thoes uppers stay, thats to hold on the plastic bit...
have you got the bottom seat out? you will see some bolts holding down your seatbelts, as well some loops that connect to the back.. take out the bolts and you should be able to lift the rear seat up towards the back window, and it should pop out
found this online by googlin
On folding seats, remove the nuts from the seat retainer at the bottom of the rear seat back, fold the seat back cushions down, then remove the bolts from the rear seat latches and take the latches off the seat back. Fold the seat back up, reposition the seat belts
and remove the seat back from the vehicle
.... who desing this car ...... can i have to cut the car in half to acess the muffler lol ?
