For sure, it's not difficult to do. There are 2 plastic pull tabs on the bottom of the lower seat that you pull out and the seat lifts up and out. The upper section is bolted in where the seat belts bolt to the car and then it lifts up off of a couple tabs and comes out. The side panels are held in with clips and I think the back deck is as well. once you get going with it you will see how it all comes out. Shouldn't take too long at all. For the doors, there are 2 round bolt covers behind the handle you pop out. You need a torx bit or I used a flat screwdriver to get the 2 bolts out. Then there are just clips holding it in. Might take a bit longer doing it the first time but you should be able to figure it out. Good luck!
