Quote Originally Posted by dagger View Post
So I have 2 10" Kicker Comp subs (Kicker CompVR 07CVR102 10" subwoofer with dual 2-ohm voice coils at Crutchfield.com), with a Kenwood 25th anniversary edition amp (Kenwood 25th Anniversary XXV-03A Mono subwoofer amplifier 533 watts RMS x 1 at Crutchfield.com). I have a box that is 1^ft in space for each sub, not ported. I have run 0G wire and some audio cables for the sub. I know I need to buy a set of speaker wire with the audio connects at the end for the stock amp (I have the bose system, unsure of where I'm suppose to hook these up? At the sub in the trunk or are there wires under the dash for it.) I also need to get a head unit as I still don't but this will need to have 2 RCA outs for both amps correct? Also can anyone point in me in the right direction for some sub boxes. I want to build one myself as the one I have now takes up a lot of trunk space and I'd like to get some back.
Well when I had my Infinity's hooked up to the Bose Amp, I used the OE wiring. I just bought aftermarket adapters from Best Buy to hook into the Pontiac/Bose connections that then plugged into the Infinity speakers in the rear deck. As for a subwoofer, I am not sure how you are going to complish that little feat. There are no connections for a subbox on the HU or Bose Amp. I am sure there is a way to hook it.
I know one guy in KC who did it, Curtis here on the boards is the person who did. I will try and find out from him.
Sorry I cant be more help than that right now.
