whats up guys. I have a 2001 GT and i'm having a few minor issues.. I have the HUD.. and it only works some times. There are times I can't see it at all no matter how dark it is outside, other times I can barely see it, others it will be bright as hell.. and I can sit there and watch it fade in and out as i drive.. any ideas?
Also, the Cruise Cont. it's sporratic as well.. rarely it will work when i want it to, other times not at all, and some times i will set it, it wont kick in, then it will randomly kick in a few mins later..
The heat on the pass. side is the same way.. some times it will work like a champ, other times it will blow air from straight outside into the car. almost as if a flap isn't closing.. If i mess w/ the climate control enough it will usually start pumping out heat.. but sometimes it will all of a sudden go from heat to the cold air outside.. in which case i have to mess the the climate control again. sometimes it will go back to heat, sometimes not.
the heated driver's seat quit working all of a sudden, can't find any loose connectors under the seat?
And lastly, is there a bulb in the on board diagnostic? it doesn't light up but if the sun hits it just right I can see what it says..
Any ideas on any of the previous problems would be GREATLY APPRECIATED. I love the car but can't stand little problems like this in my car.. If i can't find a way to fix a few of them I may start looking for myself another 240sx or a truck.. Help me out guys.
