Thread: spark plugs for minor mods
Results 1 to 15 of 15
  1. #1 spark plugs for minor mods
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    I was just thinking today. This weekend I'm installing the following:
    Wizair, overkill PCM, TB spacer and heat shield. I already have the 180thermo and 3" downpipe installed.
    My cars got 37k miles on it and its 4 years old, which isnt bad but its OEM plugs in there. Plus with the new added power I think it would be a good idea to put fresh plugs in there.
    I dont really want to put autolites in there just because they are cheap (even if they are good) but then again next spring/summer I will be dropping to a 3.5 pulley and getting a powerlog which then I will get the NGK TR6ix, so maybe I should go with the autolites since the plugs are only going to be in there for 10-12k miles.
    Which plugs should I go with for my mods? Autolite 605's? Or just go with the stock AC Delcos gapped at something different? I will get new OEM wires as well. Thanks.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  2. #2 Re: spark plugs for minor mods
    Donating Users blowfishRus6's Avatar
    g.a.
    autolite's worked great for me, i got the iridium 104's, by no means cheap, but they have held up good.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  3. #3 Re: spark plugs for minor mods
    g.a.
    get a p-log and you might be ready for a 3.5 scan first tho.. a really good investment is the aero force gauge. it reads alot of hand paramiters.
    its slow.
  4. #4 Re: spark plugs for minor mods
    Feb 2008
    South Bend, IN
    Yea I just bought an Autotap off of smoking2000gtp. Will be scanning this weekend before and after the intake and PCM. Def. will be getting a plog before I drop to the 3.5. Arent 104's 1 heat range colder than stock? Can I handle a heat range colder with intake,pcm and dp?
  5. #5 Re: spark plugs for minor mods
    Feb 2008
    South Bend, IN
    yea I think I am good on knocking down one heat range. Overkill's spark plug guide is nice.
    Ontario Quebec Club Grand Prix :: Which Spark Plugs Should I Run?
  6. #6 Re: spark plugs for minor mods
    NE Ohio
    104's are 2 heat ranges coleder than stock, autolite 605's are 1 heat range colder than stock.
  7. #7 Re: spark plugs for minor mods
    Feb 2008
    South Bend, IN
    ahh thanks for posting that. I always thought wrong then. I will go with the 605's and stock wires.
  8. #8 Re: spark plugs for minor mods
    g.a.
    i dont have any problems running 104's but since you can scan. run the 605's and see how they do, if not good enough then you can try the 104's
    its slow.
  9. #9 Re: spark plugs for minor mods
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    You'll be fine with either 104's or 605's, but if I were you I would go 605's since you're still running the stock pulley.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  10. #10 Re: spark plugs for minor mods
    Feb 2008
    South Bend, IN
    How about the AC delco 41-932. They are copper like the autolites and 1 heat range colder.
  11. #11 Re: spark plugs for minor mods
    Barksdale AFB, LA
    Not supercharged, but AL605s have been doing great in my car so far.
    2009 Subaru Impreza WRX STI
  12. #12 Re: spark plugs for minor mods
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by 04CompG View Post
    Well I haven't heard any personal experiences with those plugs, but I'd imagine that they would be fine. Personally I prefer Autolites because they perform very well in my car and they are cheap also, but to each his own.
  13. #13 Re: spark plugs for minor mods
    NE Ohio
    yeah, the ac delco plugs would work fine too. copper core spark plugs dont last as long as iridium or platinum ones, but theyre cheapers, and they pull more heat away from the cylinder. i see that as a fair trade off.
  14. #14 Re: spark plugs for minor mods
    Feb 2008
    South Bend, IN
    Well I will go with the 605's this weekend. What should I gap them at? Again my car will have: intake,pcm,3"dp on it. Thanks.
  15. #15 Re: spark plugs for minor mods
    Jul 2008
    Dekalb, IL
    A gap of .055 will be fine.
  1. Side Gap Spark Plugs [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 03-17-2010, 12:26 PM
  2. Colder spark plugs
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2008, 09:50 AM
  3. Changing the Spark plugs
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2008, 03:24 AM
  4. Spark Plugs
    Last Post: 07-27-2008, 10:45 PM
  5. A look at different types of spark plugs
    By SyntheticShield in forum General Tech Discussion
    Last Post: 04-10-2008, 11:24 AM
