Thread: Remove the factory bose amp in the trunk of my 02 GTP?
Results 1 to 3 of 3
GTPjcoop Remove the factory bose amp... 03-20-2009, 06:46 PM
GTPjcoop Re: Remove the factory bose... 03-21-2009, 09:21 PM
dstout Re: Remove the factory bose... 03-30-2009, 09:30 PM
  1. #1 Re: Remove the factory bose amp in the trunk of my 02 GTP?
    SE Level Member GTPjcoop's Avatar
    Jan 2009
    Greater Boston
    really?? no one knows anything about this?
  2. #2 Re: Remove the factory bose amp in the trunk of my 02 GTP?
    GTP Level Member dstout's Avatar
    ky
    Well, I don't know if this will help or not but if you are planning on a rewire for your system and just bypassing the bose amp then I guess you can just disconnect it. I don't know if anything else uses the amp besides the bose system I heard the onstar system also uses the amp but I don't know about that.
    I have an 03 with the bose system and that was the first thing to go it just didn't sound right and I hated it so it's all alpine now.
    The onstar isn't used and I really have not attempted to remove the amp but, if my speaker boxes wouldn't fit cause of that amp then yeah I would want it gone too.
    I suppose you could just unmount it from the trunk so you could get your stuff in and then reattach it and I would think it is just screwed to the inside of the trunk.
    I did not install my system I had someone else do it cause I was working alot so I can't tell you if anything uses the amp or not.
    I hope someone can tell you more.
  1. Bose
    By trenaro in forum Audio, Security & Visual Electronics
    Last Post: 02-15-2009, 10:02 PM
  2. bypassing Bose amp
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 02-04-2009, 11:51 PM
  3. bose removal
    Last Post: 12-02-2008, 01:20 PM
  4. BOSE with a mind of its own....
    By armcclure in forum Audio, Security & Visual Electronics
    Last Post: 09-17-2008, 02:52 PM
  5. Bose?
    By flynn in forum Audio, Security & Visual Electronics
    Last Post: 08-16-2008, 04:24 PM
